FS: 08 Corvette Z06 Golen Built Engine
Year: 2008
Make: Chevrolet
Model: Corvette
Price: $325000
Mileage: 40000
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Yellow
Transmission: Manual
Drivetrain: Rear Wheel Drive
2008 Corvette Z06 with 3LZ
Heads up Dash display
Heated seats
Navigation
40,051 miles (will go up as I still drive it on nice days)
Suspension
PFADT Street/Track Coilovers
PFADT Front/Rear Heavy Rate Sway bars
Wheels
OEM ZR1 Wheels
Stainless Braided Brake lines all the way around (If i recall Goodridge, will check to verify)
ZR1 Style CF Splitter
Side Markers Professionally painted/smoked & clear coated (PPG)
Engine (Golen Built)
New GM LS7 Block
ARP Main studs
Comp Golens Custom Spec Cam
Durabond Cam bearings
Katech High Capacity Scavenge/High Pressure Ported Oil Pump
ACL Main & Rod Bearings
ARP Crank Pulley Bolt
Callies 4340 Forged Crank
Callies 4340 Forged H-beam Rods
ARP Rod Bolts
Mahle #644-LS7105135F03 Pistons
OEM LS7 Lifters
Smith Brothers 3/8 .083 Pushrods
Manley Stainless Steel Intake & Exhaust Valves
Brian Tooley Platinum Valvetrain
Comp Cam Trunion Upgrade on rockers
Bronze Valve guides
Full K&N Intake
ARH 1-7/8 Headers X-pipe to factory Z06 mufflers
Ron Davis Radiator
OEM GM Water Pump and Thermostat 160°
DriveTrain
ACT Twin Disc Clutch
ACT Flywheel
B&M Shifter
Car Made 517RWHP (Still on Stock Intake Manifold and Throttle Body)
Here are new parts/work done within the last 4,000miles:
OEM GM Front Calipers/pads/rotors. Purchased BRAND NEW
OEM GM Front Grill Vents
OEM GM Bottom Door Jam Protectors
AC Delco Battery
Brian Tooley Valvetrain
Bronze Valve Guides
OEM GM LS7 lifters
Here is a video of the car idling:
Previous owner tracked this car on the weekend. Some minor things I haven’t had the time to get too:
Sun visors need to be put back in. +
Missing Plastic inside Halo Cover. Horn does not work. Passenger side mirror glass has light scratches.
A/C Compressor clutch needs to be replaced. Heat does work.
Previous owner jacked the car up at wrong spots which chipped the bottom rocker. For some reason part of the passenger side carpet (by E-brake) and behind the seats were sectioned/cut. E-brake doesn't work well, so i keep it in gear when its parked. Needs dealer service to check the airbag light it goes on and off and has been staying on recently.
TPMS light is on as there are not sensors on wheel. Check engine from deleted Cats o2 sensors. Does not affect performance.
Car has its normal wear and Knicks for an 8 yr old car.
Please message me for any questions.
Clean Title in hand
Located in Cincinnati, OH
I’m Asking $32,500 OBO. Make offer. Worst I can say is no. Absolutely NO Trades.
Ok I usually keep quiet but I am really confused as hell. I debated even writing this but I might be asking a silly question. I watched your video several times and there is 1 thing that bugs the hell out of me.Why in your photos your seats are nice black interior with logo stitched in the head rest. But in the video you have Red seats with holes in them? I almost think i am seeing red door panels. Can you clarify why the seats are different? thanks.
Oh and why is the tag on the car different as well. thanks.
