2002 camaro ss built heads and cam
Year: 2018
Make: Chevrolet
Model: Camaro
Price: $9500
Mileage: 100000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Mods: LS6 STAGE 2
PRC SPRING KIT
COMP CAM LSX ROCKER ARM TRUNION UPGRADE
GM LS& lifters
FAST 102 INTAKE
FAST FUEL RAIL KIT
PTM 102MM TB
SLP 85MM MAF
COMP CAM LS1 3726R/3727R HR112+2
160 THERMOSTAT
LS2 TIMING CHAIN
LS6 OIL PUMP
SUSPENSION
EIBACH PROKIT
LOWER TUBEULAR CONTROL ARMS
SUB FRAME CONECTORS
ADJ PANHARD BAR
NEW OEM STRUTS AND SHOCK
NITTO TIRES
DRAG RADIALS
SPEC STAGE 2 CLUTCH
OEM MASTER CYLINDER
OEM SLAVE CYLINDER
SPEC FLYWHEEL
STEREO
KENWOOD DECK
ROCKFORD FOSGATE 12 SUBS
ROCKFORD FOSGATE FACTORY REPLACEMENT SPEAKERS
This car just turned 100k with less then 5k miles on the mood list also the
car doesn,t leak a drop of oil I'm asking 9500 obo you can text/call 325-947-7400 for Tony
