LS Powered Mustang - LS1TECH
Vehicle Classifieds Buy and sell complete or project vehicles
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
LS Powered Mustang
Thread Tools Search this Thread
Old 02-19-2017, 02:48 PM   #1
69blueSS's Avatar
Default LS Powered Mustang
Year: 1985
Make: Ford
Model: Mustang
Price: $29500
Mileage: 1
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Gray
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Chassis
• Wilwood light weight race brakes front and rear
• Strange adjustable struts front
• Qa1 double adjustable coil-overs in rear
• Racecraft k-member and a-arms
• Team z caster camber plates
• Custom adjustable travel limiters
• Team z anti roll bar
• Team z solid upper control arms w/relocation kit
• Custom lower control arms
• 8.8 w/welded 9" ends and housing braced
• 35 spline Moser axles with 5/8s studs
• 3.89 gear set
• Lightweight spool
• Wolfe mini tubs
• Custom sheetmetal in trunk w/ lsx logo
• 5 gallon fuel cell
• Aeromotive a1000 pump and high pressure regulator
• All braided fuel lines
• Custom aluminum radiator and fan shroud
• Kirkey driver and passenger seats with black breathable covers
• Black light weight carpet
• 8.50 cert chromoly cage done by Stenod performance
• Under body of car coated with KBS coatings “Rustseal”
• Skinny kid wing
• Stroud parachute and mount
• Aftermarket Fiberglass dash
• Painless switch panel
• Racepak UDX replay dash
• Racepak pan vac sensor
• Holcomb Motorsports light weight steering column
• Grant steering wheel with quick release
• Leash Electronics Pro street wiring board
• AEM wideband and gauge
• 17" Weld Alumastar wheels
• M&H 17” front runner drag tires (new summer 2016)
• 15” Weld RTS rear wheels, 12” wide with single Champion bead locks
• Mickey Thompson Pro Bracket radials 28.0/10.5 R15 (new summer 2016)
• Light weight billet aluminum lug nuts
Engine
• 07 LS2 Aluminum Block
• Callies 4.000” stroke 24x crank
• Callies 6.125” H-beam rods
• Wiseco 4.005” bore +5cc dome pistons
• Wiseco .200” wall tool steel wrist pins
• King bearings
• ARP main studs
• ARP head studs
• Melling oil pump
• F-body oil pan
• Improved racing oil pan baffle system
• Summit SFI damper
• Comp double roller timing chain
• Crower Aluminum shaft mount rocker arms #75101
• Morel 5425 Ultra Pro lifters
• 3/8” dual taper .135” wall pushrods
• PAC 1238x valve springs
• PAC R432 Ti retainers
• PAC S128 seats
• PAC L8141 locks
• Cam spec’d by Martin Smallwood Cam motion 8620 core solid roller
• LS9 head gaskets
• Trickflow heads. Additional port work done by Brian Tooley. Chambers Soften and Nitrous exhaust ports. 60cc chambers
• Edelbrock Super Vic intake. Intake ported and port matched to heads
• 4150-4500 adapter port matched to intake
• Accufab four barrel 4500 throttle body polished #4B-4500POL
• Siemens Deka 60lb fuel injectors
• Custom steam port setup
• Meziere HD race electric water pump
• -16 AN water pump and radiator fittings
• -16 AN radiator hoses
• Proform LS valve covers 141-262
• Proform LS3/LS7 coil brackets 69521
• Firecore50 LS plug wires
• Custom Stainless headers built by Zimmer fabrication. 2” stepped to 2 Ό” primaries. 4” collectors with 4” Bassani race mufflers
• Star Machine standard vacuum pump kit
• Star Machine intake/exhaust tank
• Painless engine harness
• F-body PCM tuned with HP tuners, tune done by S&M motorsports
• Engine was freshened spring of 2016 when switched to solid roller and has 12 1/8 mile passes on it
Nitrous
• Induction Solutions 4500 Real Street plate system 6 AN feed line
• Nitrous Outlet stand alone fuel system 00-12007
• Induction Solutions 4” nitrous pressure gauge
• Induction Solutions high flow Ό turn safety valve
• Induction Solutions 10 lb bottles (2)
• Billet single bottle bracket
• Nitrous Outlet bottle heater
• Edelbrock 71900 Progressive nitrous controller
• Leash electronic single stage nitrous board
Trans
• Coan "BIG DOG" GLIDE 28" W/BRAKE, REVERSE LOCKOUT, STEEL HUB, RINGLESS AEROSPACE ALLOY SUPER SHAFT, "MAXIMUM DUTY" STRAIGHT CUT PLANETARY W/ ALUM. CARRIER, BILLET OUTPUT SHAFT, SUPER DRUM 10 CLUTCH (BLUE) FABRICATED DEEP ALUM. PAN, REID CASE & TAILHOUSING, 1.80 RATIO
• Hughes HD SFI flexplate
• ARP flex plate bolts
• Bradco custom nitrous converter
• Strange Nitride hardened transmission yoke U1667N
• Strange chromoly differential yoke
• Precision Performance Products power glide shifter, cable and adapter brackets/linkage
• Chromoly Driveshaft
Looking to get back in a street car so may consider some trades
69blueSS is offline   Reply With Quote
Old 02-19-2017, 09:42 PM   #2
AWESOME looking set up glws sir.
quadriplegic is offline   Reply With Quote
Old 02-20-2017, 11:35 AM   #3
69blueSS's Avatar
Quote:
Thanks!
Old 02-24-2017, 11:03 AM   #4
69blueSS's Avatar
bump..
Old 03-05-2017, 09:59 PM   #5
69blueSS's Avatar
ttt...
Old 03-08-2017, 09:44 PM   #6
sillysspeed's Avatar
Very nice! Free bump
sillysspeed is online now   Reply With Quote
Old 03-19-2017, 01:12 PM   #7
69blueSS's Avatar
Ad updated with parts list
Related Topics
Thread Thread Starter Forum Replies Last Post
1999 Formula Firehawk ezzlez28 Vehicle Classifieds 3 08-11-2016 07:24 PM
Fabricated aluminum valve covers 69blueSS Parts Classifieds 17 03-06-2016 03:31 PM
Holley valve covers 69blueSS Parts Classifieds 5 01-02-2016 12:50 PM
Trickflow 235's, Super vic, cam, rockers, lifters *will seperate* 69blueSS Parts Classifieds 33 04-28-2015 09:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
