Vehicles Wanted Looking for a specific vehicle? Post a WANTED thread here. DO NOT post them anywhere else!
wtt 1992 typhoon for modded ls1
Old 08-09-2009, 07:44 PM
poopman's Avatar
Default wtt 1992 typhoon for modded ls1
1992 Gmc Typhoon (#20 of 2497 in 92)it is stone stock other then ,intake,intercooler, exhaust,regulator and wheels.It has 104,000 on truck ,35,000 on rebuilt motor,just a freashing up and then reinstall.Everything works a/c rear defrost,cruise ,power mirrors, etc... EVERYTHING ON THE TRUCK WORKS ,a/c,reardefrost,power everthing etc all works.
Kenne Bell cold air intake,fuel regulator and front mount
3inch cat back
New (less then 1300 miles ago)
windows tinted not to dark but tinted
rear shocks bell tech drop springs
caltrac bars
alternator
battery
Iac
Tps
o2
coolant temp sensor
new rear window shocks
All silcon intercooler pipes and boost clamps
plugs,wires,cap,rotor
Fuel pump (walbro 340m)
Fuel tank and sender
an braided fuel line feed and return from tank to steel connections by transfer case
58 mm throotle body
has 17 x 9 zr1 wheels on front &17 x11 zr1 wheels in back with 315/35/17tires
Old 08-09-2009, 09:09 PM
DMSZ28's Avatar
sent you a PM
Old 08-11-2009, 05:46 PM
poopman's Avatar
i also have a rpm performance stage 3 turbo, datamaster, 2800 stall converter, 50# injectors, & custom chip, that is all brand new. which would make it run 11's in the quarter mile. will include for the right car.
Old 08-13-2009, 08:40 PM
Mike93Z28's Avatar
pm sent!
Old 08-13-2009, 09:05 PM
poopman's Avatar
the transmission is getting rebuilt, upgrading with 4l65 parts. very fun to drive on wet or dry roads
Old 08-19-2009, 08:26 PM
BigRobSS's Avatar
Where are you located? I might be interested...
Old 08-25-2009, 08:46 PM
poopman's Avatar
new jersey
Quick Reply: wtt 1992 typhoon for modded ls1
