Western Members CA, AZ, NV, UT, CO, NM, HI
Replacing turn signal on a 93-97 camaro
Old 11-06-2008, 09:14 PM
01SOMSS!'s Avatar
Default Replacing turn signal on a 93-97 camaro
whats the easiest way to replace a turn signal bulb in a 93-97 camaro? I know the 98 and newer cars are easy as hell,but the older cars don't have a gap behind the headlights to fit your hand in there. i was thinking maybe removing the fender wall. what do you guys do?thanks!
Old 11-06-2008, 11:08 PM
01SOMSS!'s Avatar
come on where are all the Lt1 owners at?
Old 11-06-2008, 11:26 PM
hlaalu's Avatar
hmmm im trying to think how i did it on my 96.... u might be able to get to it from under the bottom?
Old 11-06-2008, 11:34 PM
Revelation Z28's Avatar
you gotta take off the plastic lining with the air dam on it off a little and reach up.
Old 11-07-2008, 12:03 AM
nomoneyz's Avatar
Like revelation said. Gotta get it from underneath.
Old 11-07-2008, 09:05 AM
ss.slp.ls1's Avatar
+2. It kinda sucks.
Old 11-07-2008, 09:29 AM
01SOMSS!'s Avatar
someone had posted this,but i think he ment on the ls models.
First you have to elevate the car so that you can safely get under the front of it. Right in front of the right front tire you will notice several 10mm bolts holding up the plastic under panning. Remove those bolts, then drop down the plastic under panning and this will expose the back of the right front turn signal. Just reach up and twist out the bulb receptical to remove it and replace the old bulb with a 3157NALL bulb. It only takes about 10 minutes once you get the front of the car safely elevated enough to get under it.
Old 11-07-2008, 09:32 AM
ss.slp.ls1's Avatar
No, that sounds about right for a lt car. Even with my car being lowered, I still didn't have to jack the car up though.
Old 11-07-2008, 09:35 AM
L3THAL_Z28's Avatar
of course you don't...ur SRJ
Old 11-07-2008, 09:51 AM
ss.slp.ls1's Avatar
Old 11-07-2008, 11:33 AM
01SOMSS!'s Avatar
thanks!
Quick Reply: Replacing turn signal on a 93-97 camaro
