help
help
just installed long tubes pacesseters and i keep getting a code with it looks like my car is running like **** cuz when i get on it i get the check engine light to blink its a misfire the code says bank 1, sensor1, fuel trim to lean , what can be cousing this issue
i only have the primaries also and did not have a problem, i used the extensions provided by hooker tho... are you sure u didnt cross the wires or something...
i had my codes turned off for the rear 02s, cats and air
yes you should be able to use the others for the front, an 02 is an 02, it just secondaries because they plug into to the secondary ports and the pcm reads them as secondary because of that
someone let me know if im wrong, but i am purty sure i am not
http://cgi.ebay.com/ebaymotors/Parts...3A1|240%3A1318
you really only need the 2 12 inchers, but these are the only ones i found... try a shop like CMS in Lake Elsinore or STD (ask for Joe, tell him the guys from westbound sent you) in south gate (closer to you i would think) and ask them if they have any in stock
Here are some Bosch 13111 O2's. You don't need extensions with these.
http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories
