Western Members CA, AZ, NV, UT, CO, NM, HI
Clutch Recommendations?
Old 03-09-2009, 05:11 PM
bigtls1's Avatar
Default Clutch Recommendations?
My 02 z28 is gonna need a new cluch soon.
So, i need some help/advice from some of you guys experienced in this department.
1. I need a clutch that will allow me to drive the car daily but still grip if i decide to spray my car.
2. What else should i get? (pressure plate, flywheel, ect.)
3. Will i be able to do this at my house?( i am fairly good at working on cars) And if i can do this at my house, do i need any special tools?
4. Any special process in revoving the clutch? (do i have to drop the trans, etc.)
5. Any other advise would be appreciated
If there is a thread that contains all my answers then please direct me toward it and i will go away. I couldn't find any with the "search"
Thanks
Tyler
Old 03-09-2009, 05:13 PM
59 camaro's Avatar
ls7 clutch and ls2 flywheel.... make sure while ur at it replace the slave cylinder imo
Old 03-09-2009, 06:12 PM
djsanchez2's Avatar
+1 that's what i have.
www.SDparts.com = best deal on them too.
Old 03-09-2009, 06:16 PM
bigtls1's Avatar
is that a direct bolt in?
Old 03-09-2009, 06:42 PM
djsanchez2's Avatar
Yup direct replacement. Here is the direct link, they used to be 399, but went up a tad to 460. The clutch is designed for 550+hp
http://www.sdparts.com/product/SDLS7...cFlywheel.aspx
Old 03-09-2009, 06:45 PM
1Loudz28's Avatar
+1 on this setup. my friend has it and loves it
i had a spec 3 with a billet steel flywheel in my last camaro, it was my dd, and it held great but sucked driving in traffic.
Fifedogg's Avatar
Get a Textralia or Monster IMO. If your gonna spray it would be a good idea to get a good clutch in there.
Old 03-09-2009, 07:12 PM
02NBMWS6's Avatar
Seriously. Spraying an LS7 clutch is begging to pull your tranny out again.
Old 03-09-2009, 08:12 PM
bigtls1's Avatar
i am gonna run a 100 shot. ill probably end up making around 450 RWHP when im all done. Will the Ls7 hold up to this?
Old 03-09-2009, 08:15 PM
yungepjr's Avatar
another +1. thats the setup i have. excellent selection.
Old 03-09-2009, 08:20 PM
'00 formula elesone's Avatar
I have center force dual friction setup with billet fly. new master and slave....not saying the others are bad. But Ive had good luck w/cf
Old 03-10-2009, 12:22 PM
02NBMWS6's Avatar
I would look more at the torque you will be producing. If you had 450hp and 375-400 tq I wouldnt worry about it. However, youre going to be spraying so the tq will in all likelihood be above 500. I wouldnt be surprised if it was 525-550. And nitrous comes on instantly so it's going to take it's toll on the clutch.
If you dont mind replacing it eventually (sooner than a Tex or Monster) then go for it. It will drive damn nice and is cheap
Old 03-10-2009, 12:31 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
if you plan on spraying the car i would shy away from the ls7, you are simply going beyond what it was meant for in 500 lb heavier car as well. if you want to spray the car with reliability go with a tex z-grip, yeah it wont be as smooth, but you wont smoke it either
Old 03-10-2009, 12:37 PM
Banned Village Idiot
LS1BLKSS's Avatar
+1 i have this one and spraying
Quick Reply: Clutch Recommendations?
