Western Members CA, AZ, NV, UT, CO, NM, HI
Need some help, please respond back
Old 05-28-2009, 12:06 PM
Tapout97's Avatar
Default Need some help, please respond back
ok my computer was F#%^&* So i got a new one just sent it to PCM4LESS
The security light is on blinking even with new pcm bryan told me its the RELAY .... 2 THINGS
1. He said he can delete vat that goes to fuel inj
2. he says you need to find the RELAY TO VAT i have no idea where it is
will someone please respond back and give me a description of the location please.... ill even buy you a beer lol hell 36 pack your choice
help out a fellow F-BODY PLEASE !!!!!
Old 05-28-2009, 01:48 PM
Ruckus46Gt's Avatar
try a new key if a new key doesnt work its the reader. Its located in the area you put the key in and turn. My 93 camaro's vat went out hoped it was just a key but it wasnt. Had a dealership get the part and install it and it was around 350 so can probely get it done much cheaper
http://www.ls1lt1.com/forum/showthread.php?t=24800
Old 05-28-2009, 02:07 PM
hlaalu's Avatar
I think there is a way where you can disable vats using a resistor from radio shack and it will save you a lot of money
Old 05-28-2009, 02:11 PM
hlaalu's Avatar
http://www.lt1swap.com/vats.htm
Old 05-28-2009, 02:19 PM
Wicked94Z's Avatar
if he's talking about the starter relay... there's a pic in this thread.
https://ls1tech.com/forums/lt1-lt4-m...ter-relay.html
just jump the brownish and purple wires together
Old 05-28-2009, 02:22 PM
Wicked94Z's Avatar
btw you have to take out the glovebox, that's the area in the picture
Old 05-28-2009, 03:41 PM
ss.slp.ls1's Avatar
Default VATS bypass
Bypassing the VATS is pretty simple, I've done it several times.
All you need to do is measure the resistance in your pellet in your key.
http://shbox.com/1/4th_gen_tech2.html#pass_key
Then you need to get resistor(s) that match the same value. Then you splice it in the designated place shown here:
http://shbox.com/1/air_bag_disc_2.jpg
Quick Reply: Need some help, please respond back
