Urgent, please help!
Looking for good f-body shop in O.C.
I am stuck in Palm Springs/Palm Desert area in california. I am normally from the OC.
Problem is that my car broke down. It is burning a significant amount of oil, I put a full 5 quarts in and it is making a serious belt noise. Please let me know of any shops near here!I am off the 10 freeway at Date Palm Drive. If I don't get anything by morning, I guess autozone is going to get it.
Please any help is appreciated!!!
Thanks guys
edit: I'm no longer in palm springs. I got the car back to O.C., but it now seems to over heat easily and is making a wierd whistle/ticking sound. I'm a complete newb when it comes to engine work. I just need to know a good show to take it to, to get it checked out, I think it is something more serious than just a broken ac compressor.
Thanks guys
Last edited by DrifterFreak210; 08-14-2009 at 07:04 PM. Reason: Updating my situation.
Belt noise is a screeching/squealing noise in which the belt noise will increase with increased rpm. Hell worst case scenario to be 100% sure the noise is from the belt, spray some wd-40 on the belts if it goes away then comes back it's the belts and you need to change them then spray a degreaser/carb cleaner on the pulleys to clean the grease off. Depending how long you ran it on that little oil you might have messed up some bearings. What's the oil pressure reading at idle?
Ok, it ended up at a shop called JD motors. they were great guys and said that I had over filled it with oil and that my ac belt is either loose or that my ac may need a rebuild. nothing major, I guess because of the late time that this happened, I over reacted. Thanks for the help though.
I just need to know a good shop to take it to, to get it checked out. Anyone know a place that is real good with the ls1?
I think it is something more serious than just a broken ac compressor, which is what the shop said it was.
