2008 L92 GM shortblock FS. $1600~
Selling my L92 shortblock with roughly 1,500 miles. Came from a totaled Yukon Denali.
I've had the engine for some time with the hopes to put it in my Camaro, but plans have changed, and I'm going to be putting my money towards other things.
The L92 I have is a shortblock with no heads or intake. I received the Engine complete down to the manifolds and intake, but have since sold the heads and intake because I was going to swap them anyway.
The entire bottom end, and front and rear covers are still sealed by GM. Oil pan, Front timing cover, Flywheel, ALL GM SENSORS INCLUDING CAM PHAZER! This shortblock is as complete as they come.
Yes, I have all the brackets, Power Steering Pump, and AC condensor. I also still have the valley cover.
Here are pictures shortly after I started taking the top end apart.
Yes, that is residual carbon built up in the cylinder. I began flaking it off... I will use compressed air to blow them out if you choose to purchase the engine.
What are the diff in a LS3 vs L92? Ive searched but dont have time to research. Will this work with my 6.0 317 heads? Can I run it without the VVT?
