Western Members CA, AZ, NV, UT, CO, NM, HI
Fuel pump help
Old 08-25-2009, 12:52 AM
hitmanws6's Avatar
Default Fuel pump help
Hey guys, Im pretty sure my fuel pump is on its way out. It sounds like its not priming all the way, and it rough to start. But driving around its fine??? Im going to change the fuel filter tomorrow, see if it helps. If i do need to get a new one, which one should i get? And id like to do the trap door mod too. Im in Orange btw.
Old 08-25-2009, 10:49 AM
93Z28rare's Avatar
I've used the Racetronix pump with the Hot Wire Kit, I believe it's called.
Old 08-25-2009, 11:12 AM
ss.slp.ls1's Avatar
What you need to do is hook up a fuel pressure guage (I've got one) and monitor the fuel pressure at prime, idle, and WOT under load. That will tell you if you need a new pump or not. My stock pump went bad and I got the Racetronix pump kit stated in the post above. Great kit. I too did the trap door method, only way to do it IMO. Let me know if you have any questions.
Old 08-25-2009, 01:32 PM
brynnda's Avatar
"trap door, only way to do it" are you ******* kidding me? drop the damn tank and stop cutting up your car.
Old 08-25-2009, 02:16 PM
ss.slp.ls1's Avatar
A small square foot hole that will never be seen and has no affect on anything...not to mention makes future pump swaps/changes almost effortless. I've done it both ways...after doing the trap door method, why anyone would drop the tank is beyond me.
Old 08-25-2009, 02:17 PM
benoh's Avatar
It's peace of mind. some people just like to cut, some people just like to drop the rear end. The end result is the same; minus give or take a couple of hours.
Old 08-25-2009, 02:19 PM
ss.slp.ls1's Avatar
Yeah, pretty much. I'd rather save time...both now and in the future.
Old 08-25-2009, 03:01 PM
brynnda's Avatar
some of us dont like to cut up our cars, to each their own.
Old 08-25-2009, 04:19 PM
ss.slp.ls1's Avatar
Don't be a pansy...just cut it.
OP, you can look at my trap door and make the decision for yourself.
Old 08-25-2009, 04:43 PM
ZexGX's Avatar
Alex cut the trap door in my car and instead of bending the factory sheet metal back, just cut a hole outright. I finished it off with a piece of sheet aluminum over it and it is held down by 3M double-stick foam tape, and weatherstripping in the one spot that needs it. No extra noise, no extra fumes in the cabin, no water entering the cabin - nothing. It still looks exactly the same as the day it was installed... 6LiterEater has the same trap door with sheet metal panel (affixed by 3M tape) in his car - but his is painted.
Here's mine (now hidden by sound deadening):
Old 08-25-2009, 06:03 PM
93Z28rare's Avatar
Got the trap door too. But it came with the car.
Old 08-25-2009, 08:42 PM
59 camaro's Avatar
Old 08-25-2009, 08:52 PM
XpEdItIoUs's Avatar
I love cutting up my car, If you see anything that I missed without having the car fall apart let me know.
Old 08-26-2009, 02:42 AM
hitmanws6's Avatar
anybody know the cheapest place to get a pump?
Old 08-26-2009, 03:04 AM
benoh's Avatar
http://speed-eng.com/store/holley-fu...h-p-11205.html
$80 + shipping; not the best of deals but its below retail.
Old 08-26-2009, 03:14 AM
Revelation Z28's Avatar
i think i still have a stocker i got as a spare for the 94 ill see if i can find it
Old 08-26-2009, 03:56 AM
Now you have my attention
GTOSE's Avatar
Should probably change the fuel filter before you change the pump..
Trap door method is a good idea, but I would rather drop the tank instead of chopping a hole in my trunk. If you have a decent fuel pump it doesn't go out that often..
Old 08-26-2009, 08:15 PM
hitmanws6's Avatar
changed the filter yesterday
Old 08-26-2009, 08:35 PM
tripblackls1's Avatar
that windshield cowl can go
Old 08-26-2009, 09:11 PM
hitmanws6's Avatar
checked prices today. im sure autozone is on crack because they wanted 209 for a delco pump. most likely going with racetronix, just have to find the best deal now
Quick Reply: Fuel pump help
