Western Members CA, AZ, NV, UT, CO, NM, HI
help a nigga out fellas
Old 08-28-2009, 01:11 PM
99sscmro's Avatar
Exclamation help a ***** out fellas
Im trying to install a sound system in my car ive already have everything meaning aftermarket radio an eq a 4 channel amp and a 2 channel.... my question is... for the 4 channel amp do i need to run wires for every speaker or can i just run the 4 set of wires to the harness that connects to the oem plug of the factory radio.... im really stuck on this one i need guidance asap thanks guys
99sscmro is offline
Old 08-28-2009, 01:12 PM
383lt1impala's Avatar
u puttin in on 30s too?
383lt1impala is offline
Old 08-28-2009, 01:18 PM
99sscmro's Avatar
30s? Nah i was going for some 22" pero mi girl talked me out of it
99sscmro is offline
Old 08-28-2009, 01:29 PM
ss.slp.ls1's Avatar
Not sure what you're asking. But what you should be doing is running audio cables (the red & white pair of cables) from the back of your deck/head unit to each amp. From there you will run speaker wire to each speaker. Now sure how you are hooking up the equalizer to the system. Do you have any pics?
ss.slp.ls1 is offline
Old 08-28-2009, 01:35 PM
99sscmro's Avatar
im hooking up the radio to the eq and from the eq to the amps. i wanted to know if i had to run wires to each speaker or if there was a shorter way to avoid all that work
99sscmro is offline
Old 08-28-2009, 03:00 PM
93Z28rare's Avatar
Better to just run wire from each speaker to the amp.
93Z28rare is offline
Old 08-28-2009, 03:13 PM
1Loudz28's Avatar
least someone in that relationship has some common sense.
1Loudz28 is offline
Old 08-28-2009, 03:14 PM
TXZ28LS1's Avatar
your title is classic..lol.
TXZ28LS1 is offline
Old 08-28-2009, 03:45 PM
$O$OE's Avatar
Title FAIL!!
$O$OE is offline
Old 08-28-2009, 03:49 PM
Dan
Dan's Avatar
My white friends call me *****(I am white) I don't see it as a big deal.
Dan is offline
Old 08-28-2009, 03:52 PM
94'BLKBRD's Avatar
You should post this in the Stereo/Electronics section, *****.
94'BLKBRD is offline
Old 08-28-2009, 03:54 PM
1sick'98WS6's Avatar
1sick'98WS6 is offline
Old 08-28-2009, 04:14 PM
ConElite's Avatar
Get rid of the EQ and get a better stereo that has it built in.
EQ's are outdated and look chunty (and im mexican)!
Just run new wires to the sail speakers and run new wire to the harness behind the radio so you wont have to try and run new wire through the door.
I been doing car audio for years and Never once Have I used an EQ, NO need.
Pioneer every time. I love mine, Even has an RPM Guage on the actual screen which works.
ConElite is offline
Old 08-28-2009, 05:23 PM
SS#2906's Avatar
If you haven't already replaced your stock speakers, you'll want to run the speaker cables to the speakers. The fronts have 4 wires that separate the bass from the treble, if you hook them up to the harness, they won't work.
SS#2906 is offline
Old 08-28-2009, 06:17 PM
99sscmro's Avatar
I just finished with installing everything, I took your advices and ran a wire to each of the speakers . Why even get into the whole ***** thing? its not a big deal to me beeing that im mexican me and my homies nos llebamos de ****** weyes and all kind of things. I went with a alpine digital media receiver it has a built in eq already but i like the pioneer digital processor that i have it just makes corridos a hellla lot better. so thats that, everything turned out ok and thanks again guys. Real help IS appreciated
99sscmro is offline
Old 08-28-2009, 06:20 PM
hlaalu's Avatar
the easiest is to buy new speakers and run speaker wire from each speaker to the amp, then run the amp to the radio with the rca cables like srj said. you can't just hook up the wires from the harness to an amp because the stock speakers use a different setup.
hlaalu is offline
Old 08-28-2009, 06:22 PM
99sscmro's Avatar
Talking
Got it taken care of man thanks.. i did exactly what you and srj said..
99sscmro is offline
Old 08-28-2009, 06:25 PM
hlaalu's Avatar
nice.
hlaalu is offline
Old 08-28-2009, 06:32 PM
ss.slp.ls1's Avatar
Glat to help.
Old 08-28-2009, 06:37 PM
Trans Am Jam's Avatar
my niggga.
Trans Am Jam is offline
Quick Reply: help a nigga out fellas
