Western Members CA, AZ, NV, UT, CO, NM, HI
I need a throttle cable!!!!
Old 09-05-2009, 11:55 AM
m6ttop's Avatar
Default I need a throttle cable!!!!
Non traction control
Old 09-05-2009, 07:34 PM
m6ttop's Avatar
bump...
Old 09-05-2009, 08:37 PM
ZexGX's Avatar
Me too!
If you have traction control cables though there is one that is the proper length to be shortened to be used as a throttle cable.
Old 09-05-2009, 09:13 PM
TPI TERROR's Avatar
i bought mine new from the dealership about 35$
Old 09-05-2009, 09:37 PM
m6ttop's Avatar
How did you cut the metal sleeve in the cable?
Old 09-05-2009, 11:16 PM
ZexGX's Avatar
SRJ did the modification. Pretty sure he shortened it at that little black box thing above the intake manifold in the pic above.
Old 09-06-2009, 12:20 AM
impstrz28's Avatar
my brothers cable broke a while back and i just used a bicycle break cable and cut it to the length i needed. has worked great since.
Old 09-06-2009, 04:27 AM
ss.slp.ls1's Avatar
You can modify the TCS mid line to be used as a throttle cable. I did that to Zex's ride and it worked great.
Old 09-06-2009, 11:24 AM
m6ttop's Avatar
I was gonna try and shorten it but didn't know how to cut the sleeve without cutting the cable. My snips didn't cut for ****
Old 09-08-2009, 10:55 AM
ss.slp.ls1's Avatar
I used a razor blade and cut little sections at a time of the hard plastic sleeve inside the adjustment box. Then made a slit down the middle and removed each section.
