Western Members CA, AZ, NV, UT, CO, NM, HI
Tuner can't tune my car
Old 05-22-2010, 09:34 AM
wicked-98's Avatar
Default Tuner can't tune my car
The exhaust smells kinda like gas and makes my eyes sting,no smoke other than a little condensation before it warms up.The tips are not all sooted up so I don't think its running rich.I done a engine swap a few months ago and took it to get tuned.I am about 40 to 50 hp low and the tuner said that I had a bad cam or a bad cam install but I opened it up and it looked ok, dot over dot.My mods are full exhaust, ported throttlebody,lid,some kinda aftermarket cam I got for free don't know the specs but I know it made some good power on a blower 346 setup.Hope some one can help
Old 05-22-2010, 09:40 AM
lt1pwr1's Avatar
Try a different tuner who is maybe a little more competent? That is of course assuming you DID do everything correctly on your end.
Old 05-22-2010, 09:46 AM
BADD SS's Avatar
What hp did you make? Saying you are down 40-50 hp, and not saying what you made is kinda silly. Especially without knowing the cam specs, is it a blower cam, or was it just on a car with one...?
Old 05-23-2010, 03:41 AM
Paint_It_Black's Avatar
I would be floored if a tune picked up 50 rwhp. Highly unlikely.
Old 05-23-2010, 08:18 AM
eamador11's Avatar
top tuners i would go to in cali are andy at A&A or Charlie at RPM Motorsport
Old 05-23-2010, 09:28 AM
crainholio's Avatar
I am about 40 to 50 hp low...
Show your math.
Old 05-23-2010, 01:50 PM
Blower cams are usually on the small side and on a wider LSA than N/A cams. Blower cams help the blower make power, they aren't huge power adders by themselves. Your tune might be right on.
Old 05-23-2010, 08:58 PM
nysbadmk8's Avatar
Unknown cam and you are expecting a certain dyno #? your kidding right?
Also.. did you degree your cam in? or just dot to dot? cam could be ground wrong.. but since
Old 05-23-2010, 09:01 PM
Ws6kid.'s Avatar
i think u would need some info on the specs to know how much power you may be under on
Old 05-23-2010, 09:23 PM
DSkyles's Avatar
The eyes stinging means that it's running lean. Pretty much you have a blower cam in a n/a car......Does that make sense?
Old 05-23-2010, 09:45 PM
11 Second Truck Club
MPFD's Avatar
My tuner found 58 rwhp in my tune, to be exact.
Old 05-23-2010, 09:56 PM
Old School Heavy
speedtigger's Avatar
He said it smells of gas. The stinging of the eyes and the smell of gas means extremely rich not lean.
A blower cam typically has wider lsa. This would not lend itself to raw fuel in the exhaust.
If you have raw fuel in the exhaust, you can look for a stuck or leaking injector, excessive fuel pressure, substantially out of range fuel calibration from the computer or even excessively advanced timing.
I am surprised you are not throwing a code.
Old 05-23-2010, 10:09 PM
LilJayV10's Avatar
Old 05-23-2010, 10:47 PM
LSX Mechanic
Damian's Avatar
It "looked" ok? Do your eyes have a built in degree wheel? If not, then you really have no clue what you're looking at. "Dot to dot" could still mean it's 2-4 degrees out in either direction depending on the inaccuracy of the cam grind itself, and chain slop.
With statements like this, it's really no surprise your car doesn't make the power you want it to.
No.
Old 05-23-2010, 10:52 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Well, in that car an LS6 cam would be considered and aftermarket cam. This thread pretty much sucks and I am surprised it is still open. But I think we all want to see your next post.
So you deleted that post....^^^ Does that mean its not true?
Old 05-23-2010, 11:08 PM
LilJayV10's Avatar
This thread has all the essential parts to be epic....
Old 05-23-2010, 11:14 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Its coming into its own, thats for sure. I am just waiting for him to tell us that #7 is hurt.
Old 05-24-2010, 03:47 AM
02*C5's Avatar
Epic Hell y say something and stop him from saying something else he seems to be on a roll
Old 05-24-2010, 09:00 AM
wicked-98's Avatar
Take it easy guys lol.The person who gave me the cam said it was a blower cam and he couldn't find the specs sheet for it.Now that I read a few of the post I can see why I'm low on hp.I made 320 hp or something around those lines and the power band fell on its face at about 3800 rpm.The smell from the exhaust is like a gas smell but I don't think its running rich (no black smoke).I tried taking a short cut by getting a free cam and now I will be spending some money on a na designed cam.About the timing where is it soppose to be for a stock application.I wanna compare to my timing now
Old 05-24-2010, 09:10 AM
MPFD's Avatar
No its was true, after posting I just didn't wanna get into the arguement...
My tuner sent me a stock LS2 tune corrected for the 44 lbs/hr injectors I had in the truck, just to get me down to his shop. The first pull unlocked came in at 268 rwhp, when he was done it made 326.7 rwhp unlocked in third.
http://i152.photobucket.com/albums/s177/MPFD/dyno.jpg
Quick Reply: Tuner can't tune my car
