Western Members CA, AZ, NV, UT, CO, NM, HI
Brake pad falls out??
Old 06-23-2010, 12:54 PM
r0nz28's Avatar
Default Brake pad falls out??
Well driving the other day and my brake pad falls out (rear driver side) never heard of it before and all my other brakes are fine. So now looks like I need pad, rotor and caliper. ANy body in the LA area have these parts laying around ? I will probably buy pads from a store but wold love to save money on one rotor and caliper Until I change out all rotors and pads on payday
thank you
ron
Old 06-23-2010, 01:38 PM
ss.slp.ls1's Avatar
Never heard of that either. Try hitting up the junkyard.
Old 06-23-2010, 05:24 PM
ZexGX's Avatar
I'm trying to figure out how a brake pad could possibly fall out without the caliper itself having prior damage...
Old 06-23-2010, 06:02 PM
383lt1impala's Avatar
Maybe its the same wayy ivan had a chunk of his piston missing and it was no where to be found.
Old 06-23-2010, 06:35 PM
ss.slp.ls1's Avatar
I would seriously check all of your other brakes to see if everything is tight and normal.
Old 06-23-2010, 07:08 PM
FBDYLVR's Avatar
Caliper pins seized?
Old 06-23-2010, 07:17 PM
180ls1's Avatar
agreed, and depending on how long you have had the car and how much time you have i would crawl around the car and look for anything else weird.
Old 06-23-2010, 08:03 PM
r0nz28's Avatar
yea I'm going to swap out the fucked up **** and when I get paid re-do all rotors, cali's, and lines and all that . thanks for the info and help
Old 06-23-2010, 08:57 PM
LS1Adam84's Avatar
That is really odd, maybe the pad said screw this I'm outta here and took off.
Old 06-23-2010, 09:16 PM
vrtch ss's Avatar
I have a caliper set in storage, don't remember if they were front or rear tho, I will check.
Old 06-23-2010, 09:35 PM
r0nz28's Avatar
thats what it feels like! lol
Old 06-23-2010, 10:44 PM
2000SSgeorge's Avatar
I have a full set but I'm in the IE.
Quick Reply: Brake pad falls out??
