no radio no fogs no gauge cluster
So I go to my car an unlock and it doesn't flash the lights. then I start the car and my gauge cluster doesn't light up. my radio wont turn on. its ligts are off.. And the fog lights don't turn on either.. my headlightswork. my drlwork. my turn signal works. my break lights work... help is appreciated
oh and the only needles that work are the oil pressure and battery. rpm speedo temp and fuel don't move an inch
are the interior lights working? power windows?
sounds to me like the BCM but i'm not certain what all it controls in so far as the gauge cluster. I know it controls keyless entry, lights flashing, radio, power windows and interior lights.
second thing would be the headlight and/or high beam switch.
Last edited by 1ltcap; 01-25-2012 at 11:47 AM. Reason: 'cause i friggin felt like it. nosey bastage.
Make sure your checking the fuses with a DMM not just looking at the fuses for an open. The "Gauges" fuse is used by the Instrument Panel, BCM, Stop Lamp Switch, Daytime Running Lamp Module, and Traction Control Switch. The "Gauges" Fuse is powered by a fusible link located in the engine bay, Right on the battery power supply cable post on the fuse block. You can try the grounds circuits too, But most the interior switches and interior modules share this ground and would also be having issues. It is located on the dash support bracket behind the left kick panel.
We found a burnt tail light fuse (don't know why since tail lights do work) and replaced it. the new fuse blew. earlier in the week I had replaced two bulbs that have been out for about 4years( yes the right bulbs werecorrect.)
my bro got the cluster lightsto work but gauges still don't. and radio still don't..
my bro reinstalled. the bulbs.
bow what
everything works minus gauges and radio
bow what
Ok everything works
tailights work
fogs work
headlights work
lock/unlock works and beeps
gauge cluster lights up
radio lights up
but..
when locking/unlocking it doesn't flash the lights
the radio screen still wont turn on(only the lights when I turn on the cluster as stated before)
the tach speed gas temp gauges don't work
And now my right headlight doesn't go up.. it turns on but doesn't go up
WTF
tailights work
fogs work
headlights work
radio lights up
but..
WTF
hey yall I just ran in to this some what same problem two night ago , my lights to my cluster gauges are not working along with my radio lights but the radio works i check this fuses and i found my tails and brake lights fuse was burnt out but didnt fix the cluster light problem i just replace my turn signal light bulb and this just happen day after . i do have sequencental tail light i install back in october but this problem im having is this first time having but i dont think that causing it can any one help!!!! please
