Is it hard to connect gauges?? - LS1TECH
Western Members CA, AZ, NV, UT, CO, NM, HI
Thread Tools Search this Thread
Old 03-13-2012, 05:49 PM   #1
chevystyle's Avatar
Default Is it hard to connect gauges??
Wanna get Oil Temperature and wide band O2. Maybe a 3rd one....but can't think of a 3rd one. Can you?? Wanna get a 3-gauge pod for the pillar.
Thanks.
chevystyle is offline   Reply With Quote
Old 03-13-2012, 09:45 PM   #2
MrElectric03's Avatar
Oil temp is not bad, youll tap into a wire off of the computer for an electrical one or install a fitting and run a tube though the firewall for a mechanical.
For a wideband youll need to weld in another oxygen sensor bung into the exhaust.
Is your car an auto? of so trans temp is good to watch
MrElectric03 is offline   Reply With Quote
Old 03-13-2012, 10:36 PM   #3
cntrmnt02ss's Avatar
fuel pressure, or no2 pressure are also possibilities
cntrmnt02ss is offline   Reply With Quote
Old 03-16-2012, 01:22 PM   #4
Ray455's Avatar
Not trying to thread jack, since it'd probably be good info for OP too, but anyone know the easiest place to run the senders through the firewall? Have everything hooked up, just need the senders run for a trans temp and oil pressure gauge (both electric)
Ray455 is offline   Reply With Quote
Old 03-16-2012, 01:29 PM   #5
I usually run my stuff through the whole behind the pcm. there is a big grommet there if you pull out the pcm
allblacksrt4 is offline   Reply With Quote
Old 03-16-2012, 03:29 PM   #6
ZexGX's Avatar
ZexGX is offline   Reply With Quote
Old 03-16-2012, 08:21 PM   #7
Quote:
ditto
Old 03-17-2012, 12:38 PM   #8
Ray455's Avatar
Good info, glad I didnt start hacking stuff up lol. Thanks a lot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
