Western Members CA, AZ, NV, UT, CO, NM, HI
Better light output on LS1 Camaro Fogs. ((((WARNING LARGE IMAGES))))
Old 05-31-2012, 04:54 PM
0235SS's Avatar
Lightbulb Better light output on LS1 Camaro Fogs. ((((WARNING LARGE IMAGES))))
So I always wondered why the heck GM didn't do better on giving us (98-02 Camaro owners) brighter fog lights...
I hate the fact that instead of using real projector fogs they made some crappy *** fogs with a shield inside to give them the projector look. I ended up opening the fog lights by removing the lens with a small flat head screw driver (ones to open up watches with) be very careful because the lens can easily crack (use a heat gun if you have one in handy), then remove all the silicon with a razor blade. I would recomend since the lense is out clean it with some meguiars ultimate compound, then there's a shield in the middle inside the fog light, all you have to do is push it in from the sides and it should pop out,*also what i would recommend would be to go to any auto zone or even on Amazon.com and buy one of those aerosol chrome paint cans and spray the inside* no matter what it will be brighter since you will be removing the shield that blocks off light output. after you do the last steps just simply apply clear silicon or use a silicon glue gun... all done, try it out and post up your results and feedback on here. '''
Old 05-31-2012, 05:12 PM
The Guz's Avatar
Intertesting. Any output pics to see the difference?
Old 05-31-2012, 05:24 PM
0235SS's Avatar
yeah ill upload them when i get home, i have some before and after, keep in mind you will loose the straight "projection" output the fogs give. its worth it in my opinion.
Old 05-31-2012, 05:45 PM
lilpb1's Avatar
sounds like an easy upgrade what did you do about the all the pitting on the glass?
Old 05-31-2012, 05:56 PM
djsanchez2's Avatar
So when are you going to do mine?
Old 05-31-2012, 05:57 PM
0235SS's Avatar
i tried sanding it with a 500 grit but didn't do much so then i sand it a bit with a 1500 and buffed the heck out of it, came out how it was before so i left that alone
Old 05-31-2012, 05:58 PM
0235SS's Avatar
Danny, dawg... if i can do this you can easily do it... i did it on mine cus i wouldnt care breaking my **** lol, but your or any other peoples i wont do lol its easy as heck bro, trust me..
Old 05-31-2012, 07:52 PM
karkrazie626's Avatar
This mod is blast from the past. Good to see people still getting the most out of ours cars as possible. Also look up the low beam/high beam mod, if you haven't already. The low beam stays on when the highs are activated.
Old 05-31-2012, 08:25 PM
0235SS's Avatar
yeah thanks bro, (i searched for something like this, never found anything) ill pass on the highs and lows staying on together since cops are dicks out where i live and get anyone with HID low beams so i keep the highs on stock bulbs. thanks again.
Old 05-31-2012, 08:55 PM
Just noticed the ten year member lable! Wow it make me feel old, but in a good way.
Old 05-31-2012, 10:38 PM
0235SS's Avatar
UPDATED PICS
BEFORE
AFTER
Old 05-31-2012, 10:54 PM
Regulator's Avatar
Looks like a serious amount of glare
Old 05-31-2012, 10:58 PM
KWIK WS6's Avatar
OMG, your going to blind everybody.
Old 05-31-2012, 10:59 PM
0235SS's Avatar
not really too much, i guess the camera makes it seem like there is, heres another pic from a different angle after the mod.
Old 05-31-2012, 11:46 PM
lilpb1's Avatar
Looks good, big improvement. I was planning on replacing my fogs for some projectors but this looks alot easier.
Old 06-01-2012, 01:42 AM
0235SS's Avatar
yeah bro, honestly the glare is not that bad, besides keep in mind im using HIDs
Old 06-01-2012, 11:02 AM
ROCNDAV's Avatar
I wish the pictures were uploaded to LS1Tech.
My company blocks all sites like photobucket and the rest
Old 06-04-2012, 02:35 AM
0235SS's Avatar
quick video after mod
http://www.youtube.com/watch?v=Jldf8...ature=youtu.be
Old 06-04-2012, 11:24 PM
ConElite's Avatar
Im sure there is more light but the purpose of that cross bar is to give you a nice Light pattern.
Now it just seems like you have scattered light.
Quick Reply: Better light output on LS1 Camaro Fogs. ((((WARNING LARGE IMAGES))))
