Problem With My CHEVY BLAZER HELP!! Steering Lock
The steering wheel get stuck as if the keys are outta the ignition...but if u turn real hard it turns a bit.Any suggestion our advice?
Start with the simple stuff. Sometimes if you're parked on a slight incline, it will make enough tension on the lock so it won't release. Try gently rocking the vehicle forward and backward either with one foot on the ground with the door open, or bobbing your shoulders forward and backward while seated. Or, just get a friend to push on the outside of the vehicle. Make sure the keys are in the ignition in the "on" position.
