AZ Smog and emmisions Questions
I have an 85 c10 and I'm swapping a 5.3 into it i live in AZ but I'm unsure if I have to keep my smog pump/system. can someone clarify?
azdeq, says that what ever smog related your truck came with from factory need to be present on the truck.
i would look under the hood at the factory decal and see what the truck had (i.e) cat,egr,smog pump.
you can also call azdeq and see if there is change to the law, and maybe you can get the truck changed to a obd2 specs?
same with my gto, but its a obd2 car.
his truck is a 85 and they will run it as such, so it has to do the im137 rolling test and gets a full visual inspection. so any of the original emission devises that are not there, will fail him.
he can only hope that he might get a variance is he upgrades the truck to a complete obd2 system? but i dont believe that az allows this. they pretty much go by the year of the vehicle and emissions at that time.
I called they said that because I'm swapping an engine with OBD2 that I could get a conversion and I would be able to take of my smog pump and all that nonsense
