California - smog info needed about tune.
I live in California, and what I plan to do is put long tube headers and give it a tune (maybe LS6 intake if I can get the funds by then).
Question #1: (not really related to thread) If I get headers WITHOUT AIR/EGR, can I just simply plug the AIR/EGR valves that would go into the header plugs (which are not there)? Would that be the same as removing it, without actually removing it? (I want to keep it for future smog purposes).
Now, question #2, the main question: If I get headers and get a tune, will I pass smog IF I change my headers back to the stock ones? Or would I have to re-tune with the stock headers to pass smog? I plan to keep the stock headers with the cats for smog, I just want to know if I will be able to pass smog after getting a tune with long tubes, and switching back to the stock ones.
Question #1
Yes, just get some block-off plates for the AIR/EGR mounts on the headers.
Question #2
I would recommend having it tuned for the stock exhaust manifolds & cats. If you switch it back to stock after getting it tuned for LT headers & ORY-pipe you'll likely FAIL smog. I'd talk to your tuner he should be able to explain this a lot better then I can.
Question #2
I'm sure you could use the block off plates in the opposite way to block off the AIR/EGR lines (opposed to the headers like most use them for), however at that point I think that you would be better off getting headers with the emissions ports. If you get "race" headers and keep the AIR/EGR lines in the car I would assume that they would be flopping around in the engine bay which probably wouldn't be good.
Pontiacerator
Your best investment would be in EFILive or HPTuners. That way when you reinstall the stock manifolds and cats for inspection, you can reflash it to the stock tune. Then once you pass, pull them off and reflash your LT tune. You're in control and you don't need to rely on a tuner.
I'd definitely get LT's with EGR and AIR ports to save the hassle of reinstalling those systems as well as the manifolds and cats. Be careful to get good quality, because those tubes have been known to break off.
Lastly, you're a better man than I to go through a complete header uninstall and install every two years. If I move back to CA full-time, I'll stick with manifolds and cats. That's the plan for my M6 car.
