FREE stock Torque Arm and Panhard Bar
Parts added... 2001 Camaro rear axle Bearing and seal NATIONAL part num. 5707bearing and 8660s for the seal, only one of each. Also have the radio bezel for same car. The bezel was cut to fit a double din stereo so it's no good. ABS, ASR switches are good, the vents and CAMARO logo are also good. I do have a stock exhaust bracket/hanger. Also have a Powerdyne boost gauge, just gauge nothing else. These parts must be taken all together including Panhard bar and torque Arm. Price is $15 or 12 pack of beer "sorry for the bad picture, can send more if needed...
I also have the 10 bolt 4 channel, out of the 2001 SS, was starting to make bearing noise, possibly the carrier bearings. I upgraded (if you can call it that) to Moser 9" and had to use the stock axle rings for the abs/Trac so those aren't ava. Rear had 70k when taken off.. Make an offer
