What's up fellas! Going to Fontana to drag race
My buddies and I are going for the first time to drag race on feb 28th it would be awesome if down of you guys wanted to Come with. I don't really know a lot of people with FBodies but sure wish I did ! I'll be fun and Interesting what our cars put down
Let me know if you guys wanna roll up
Uhhh, I don't know about that. My car has an open downpipe, no muffler. But they also did not make me start my car for the tech inspection. You SHOULD be ok on the noise part. Just the basic stuff: Up to date cert Helmet, proper clothing, battery tie down, adequate coolant overflow, etc.
If you go on a test and tune day (normally Saturdays), they are less strict on the noise but still just as strict on everything else. It will cost more to run then a normal open strip day though.
Motorcycle helmet is fine. I think it just needs to be SNELL 2005 approved. As for your battery, if it is not secure, they wont let you in. I have seen people use a normal tie down strap (ratcheting style preferred) and they let them through. Main point is to make the battery seem like it is mounted solid and not going anywhere. Make sure you also have a coolant overflow in working condition. If your car leaks oil, you might want to give the oil pan a quick wipe down before you go. If they see it dripping, you will get denied. If you are going to run slicks, you better have the correct studs and nuts sticking out. Its all the little things they get you on.
Sup guys just came back had a bunch of fun
The rules were not even enforced they were super chill
Best time I went 12.9
It was way harder than it looks to break lower numbers
243s
torquer v3
Full exhaust
Tune
3.42s
Brand new drag radials
All little bolts ons
Full suspension
Ccw classics 17x9.5 17x12
M6
Ls6 intake
42lb injectors
torquer v3
Full exhaust
Tune
3.42s
Full suspension
M6
Ls6 intake
42lb injectors
People here have been saying low 11s with my set up but based on what we did today it feels impossible people are even saying 11s without cams and pure bolt ons
Idk what to believe .
