Western Members CA, AZ, NV, UT, CO, NM, HI
Need to pass CA smog with 224 cam
Old 03-20-2017, 02:03 AM
Rob98LS1's Avatar
Default Need to pass CA smog with 224 cam
I have a few months before the car is due which is why I want to address this now. I have TR224 114 LSA with stock tune on a 98 ls1. Has anyone passed CA smog without it getting tuned or other comparable small cam? Everything else is good to go (ie. stock manifolds, stock cats, all smog equipment installed, no codes). The exhaust periodically gets a sulphur smell which from my research suggest the cats are being affected by the rich air/fuel mixture from the cam and can eventually fail. Any input would be appreciated.
Old 03-20-2017, 10:05 PM
silvea's Avatar
Get someone to pass it for 150-250 and call it a day?
Old 03-23-2017, 04:10 PM
96darkhorse's Avatar
Rob98ls1, if you need help with this , pm me
Old 03-24-2017, 01:42 PM
GasTiresandOil's Avatar
Get it tuned and you should be able to pass no problem.
Why are you running around with an aftermarket cam without having it tuned? Do you realize how much power you have left on the table without having the car tuned?
Old 03-25-2017, 09:48 PM
xdanny510x's Avatar
With that cam u can pass a test! Just get it tuned..
Old 03-25-2017, 11:39 PM
2002kirk's Avatar
If you cant get it tuned in time. just head to chula vista and im sure youll find a shop thatll pass your car. itll cost a bit more, but they will pass it.
Old 05-21-2017, 07:08 PM
AiDRocks's Avatar
So what was the outcome? I'm curious to know.
Old 06-08-2017, 02:08 AM
Rob98LS1's Avatar
It actually passed smog at about stock readings. Still looking and ready to book a northern california tuner to dyno tune the car. Any suggestions welcome.
Old 06-09-2017, 05:47 PM
willis b otch's Avatar
Passed smog, no tune on 98 ls1 with 224 on 114 for years I always wondered about this cam for CA the biggest cars in all the reads here on tech this biggest cam you can use. Shiet past couple weeks I been reading all over the place for smog legal h/c/i setup looking biggest cam and headwork in 01 Silverado 5.3 using stock manifolds.
Old 06-22-2017, 12:05 AM
AiDRocks's Avatar
Synergy in Livermore
Old 06-26-2017, 11:29 PM
RooRnZ28's Avatar
I agree, take it to Rick @ Synergy. You'll be happy you did!
Quick Reply: Need to pass CA smog with 224 cam
