Western Members CA, AZ, NV, UT, CO, NM, HI
Race Short Block [feeler]
Old 06-05-2007, 02:52 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Default Race Short Block [feeler]
W2W Built 408
4.030 Bore Race Prepped Iron Block
Callies Compstar Rods ARP2000 rod bolts
Any Compression Wiseco Pistons
Eagle Crank
Coated Main Bearing
Coated Rod Bearings
Coated Cam Bearings
ARP Main Studs
0-ringed Deck
9/16 Head Studs Included (7/16 stock)
Hellfire Rings
This Motor Can be built for any compression Needed. I'm thinking about Going with a larger Bore
The machine work to duplicate this block alone is over 1k.
Will sell for $5500
The Motor Will handle insane amounts of boost or nitrous. most go with 1/2 upgraded studs this is a 9/16 head stud.
ALLBOTTLE is offline
Old 06-05-2007, 03:13 PM
XpEdItIoUs's Avatar
Good short block.
XpEdItIoUs is offline
Old 06-05-2007, 04:06 PM
XpEdItIoUs's Avatar
Alex, Are you at that point where you are changing your mind about your setup but already purchased stuff?
Old 06-05-2007, 04:27 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
I purchased the shortblock a while ago,
It's hard to find competitive race heads on a 4.030 bore. with a 4.155+ bore i can get a head that will give me a better chance of Running with the Wild Street Guys (170+ mph).
The chassis stuff is getting finished up as soon as the man in brown drops it all off. once i buy the heads i'm locked in so i want to see if i can sell this block and go bigger before i pull the trigger for the top end.
Old 06-05-2007, 04:36 PM
XpEdItIoUs's Avatar
What about powertrain control, what are you going to be using?
Old 06-05-2007, 04:42 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Either the new AEM EMS or BS3
