Western Members CA, AZ, NV, UT, CO, NM, HI
Who makes best 93 LT1 Carb?
Old 06-13-2007, 07:05 PM
1badchicken's Avatar
Default Who makes best 93 LT1 Carb?
I want to upgrade to a fully polished throttle body, but which one should I get?
Old 06-13-2007, 07:11 PM
hashtagBMW
Speed Density's Avatar
Carb or Throttle body?
Are you on a Carb Intake? Or maybe just the stock Intake?
Holley and Arizona Speed and Marine are the best bolt on peices.
Tony.
Old 06-13-2007, 07:30 PM
Default lt1
I want to replace my throttle body with a bigger one but I want to buy the right one. I have a stock 93 lt1 with 30,000 original miles and I dont plan to change computer programing just want a upgrade. what do you guys think
Old 06-13-2007, 08:07 PM
hashtagBMW
BBK
Holley
Arizona Speed & Marine
Stock Ported
Those are your options.
Tony.
Old 06-14-2007, 12:17 AM
Default throttle
I heard some stick some have problems. I want the best. Somebody has to know.
Old 06-14-2007, 01:44 AM
6LITEREATER's Avatar
I would say the highest quality is Arizona Speed Marine... Get the 52mm and it will match your stock opening (your stock TB is 42mm but the intake behind it is 52mm).
If you get 58mm you will have to dremel open the intake some.
Old 06-14-2007, 01:13 PM
Rob 94Hawk 319's Avatar
Stock LT1 TB size is 48MM. Some of the older BBK do have sticking problems. Make sure you get one specifically for the 93 as they are a bit different than the 94-97.
Old 06-14-2007, 01:35 PM
Typo... I meant 48mm for the stock TB
Old 06-14-2007, 02:03 PM
Default throttle
Would it make the car run better is I opened it up even more. Keep in mind I dont want to change the computer programming.
Old 06-14-2007, 02:22 PM
I was into LT1's for a long time and I was always under the impression the factory full intended the motor for a 52mm TB (hence the intake's 52mm opening) and due to noise restrictions had to bottle neck it to a 48mm (like the added silencer)...
If you add (to your stock car):
K&N FIPK (usually $100 on ebay)
De-Screen the MAF Sensor (pop it out)
1LE Bellow ($30 new from GM Parts Direct)
52mm TB
You will NOT need programming and your car will DEFINETLY run better
Go to a 58mm on a stock engine and you might not. I remember people loosing torque on stock motors with the bigger TB's...
Old 06-14-2007, 05:18 PM
Default throttle
Thanks for the help I will buy the 52 mm do you know a bussiness I should be able to get the best pricing.
Old 06-14-2007, 05:51 PM
04gtoBMXracer's Avatar
asm 52 mm ???!!!
Old 06-14-2007, 09:32 PM
I'd just start clicking on sponsor links (to the right) and compare prices...
Thunder Racing
Texas Speed and Performance
MTI
Etc...
