question on cam for CA smog?
Yep. I have come across plenty of these posts and 224 is as big as you want to go and PASS. another thing to watch out for is the LSA. Anything below 114 LSA is questionable. I have come across 112 LSA passing, but having to tune it just to pass then re-tune to drive it. 114 LSA have been smogged and passed.
224/581/114 cams seem to do just fine. Anything bigger may be a problem.
Hey Ryne whats the most common(best) cam used on 01-04 Z06 that still passes smog?
Passing is for sissies. Man up, put in the beefcake, and take your beating like a man when CHP stops you and assaults you for driving a modified vehicle. Or, just tell him you smoke ricers. CHP loves hearing kill stories about imports getting waxed.
LS1TECH Sponsor
i have using 224-228 on 114+2 it really makes good power and still passes emissions ( i have a smog guy next door to me, he will throw it on the machine to see if it passes ) but that cam for your z06 would be perfect, really a great all around camshaft, plus i usually keep them in stock.
