Western Members CA, AZ, NV, UT, CO, NM, HI
Speed Density tuners in so. cal......
Old 02-20-2008, 11:44 PM
1SLO6's Avatar
Default Speed Density tuners in so. cal......
who tunes a speed density style car in so. cal????? I have a 93 Camaro that needs a re-tune....after 6 speed swap and long tubes.... running a little rich.... any info will be helpful.
Old 02-23-2008, 12:32 PM
wicked z28's Avatar
Not sure but try cms in corona
Old 02-23-2008, 12:34 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i cant tune the 93's because i dont have a chip burner
Old 08-08-2008, 03:05 PM
1SLO6's Avatar
bump.....
Old 08-08-2008, 04:00 PM
MSS91Z28's Avatar
PM Kevin91Z, he is located in Orange.
Tunes thirdgens but can tune an sd lt1..
Old 08-08-2008, 04:53 PM
Raptor_WS6's Avatar
try std
Old 08-08-2008, 05:15 PM
Sommer86's Avatar
Hey Ryne, you can do speed density tunes period?? SWEET!! Any draw backs vs. a dyno tune?
Old 08-08-2008, 05:16 PM
Raptor_WS6's Avatar
hmm, mike, an SD tune is just a MAFless tune, you take out the maf
they both can be done on the dyno
Old 08-08-2008, 05:28 PM
BigDaddyBry's Avatar
Originally Posted by Raptor_WS6
try std
Had some, don't like them very much.
Old 08-08-2008, 05:35 PM
Sommer86's Avatar
then whats the tune thats done while you're driving??
Old 08-08-2008, 05:42 PM
Raptor_WS6's Avatar
umm, a street tune
Old 08-08-2008, 05:56 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
yeah i can do speed density tunes on lsx platform vehicles. why do you need it though? are you running a large camshaft, or a turbo?
Old 08-08-2008, 06:06 PM
Sommer86's Avatar
aaahhh... I didn't know what they were tunes for. I had just heard that street tunes were more accurate to street conditions. I didn't know you needed a big cam or turbo.
Thanks!
Old 08-08-2008, 06:17 PM
ThirdGenLS1's Avatar
you dont need a large cam or turbo, its a general the fact that they run better with a sd tune. Sd is just another way to calculate air charge coming into the engine, doesnt necessarly mean its better or worse then a maf just different ways of coming to the same result.
Old 08-08-2008, 06:25 PM
02NBMWS6's Avatar
for a bigged cammed car, a SD tune is better. for a turbo car, a SD tune is better. for a stock car, a MAF tune is better.
Yes, they are both just different ways of calculation, but there are advantages to be had from a SD tune on particular types of setups. Thats something that i would consider "better"
sommer86 - Ryne tunes the car on the dyno and the street, youre right, sometime the car's dont act quite the same on the dyno as they do the street because of the differences in load. Ryne's particular type of dyno really helps to overcome this, but he still takes the car out on the street to verify. Once you get a big cam, or turbo then you will want a speed density tune.
Old 08-08-2008, 07:46 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
you dont need a large cam or turbo, its general the fact that they run better with a sd tune. Sd is just another way to calculate air charge coming into the engine, doesnt necessarly mean its better or worse then a maf just different ways of coming to the same result.
never said it needed, but otherwise its overkill, regardless i make changes to the ve table anyway then reengage the maf
Old 08-08-2008, 08:22 PM
wasn't correcting you ryan just giving him information
Old 08-08-2008, 08:24 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
sorry i am in a little touching mood, lol my bad
Old 08-08-2008, 08:28 PM
hlaalu's Avatar
whats the benefit to not having a maf?
Old 08-08-2008, 08:36 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
well on more radical combinations like lets say big cam cars, you eliminate the reverison going out past the maf sensor, coming from the motor do to the cams overlap. a probably tune sd car will fuel exactly to what motor needs. but there one issue is obviously smog (you need the maf to pass smog) which might a non issue anyways with a large cam car. and it cant make as much adjusts itself, as the maf car can. generally i tell customers if the car is mild in performance parts, just run it with the maf, if you have a more radical combination then go speed density
Quick Reply: Speed Density tuners in so. cal......
