Western Members CA, AZ, NV, UT, CO, NM, HI
HELP!!! Car goes straight to REDLINE on Start-Up!!!
Old 03-18-2008, 02:08 AM
GTObsessor's Avatar
Default HELP!!! Car goes straight to REDLINE on Start-Up!!!
Just like the description states, car goes STRAIGHT to redline (as if the throttle body's stuck open) on startup and pings the limiter. Was working perfectly fine this morning. Help plz!
Old 03-18-2008, 02:12 AM
ae13291's Avatar
it could be your throttle position sensor? check the tps sensor or disconnect it, also check the throttle body seal and check the seal on the intake air control solinoid too
Old 03-18-2008, 02:15 AM
GTObsessor's Avatar
TPS sensor is the black blockish thing on the left of the throttle body, correct? How would I go about disconnecting it? Where's the intake air control solenoid located? Thanks.
Old 03-18-2008, 02:25 AM
GTObsessor's Avatar
I'm gonna hurt someone. The cap off the intake (not sure what it's called, blocks the EGR hole on top of the LS1 intake) MAGICALLY came off. WTF?!?! It was there this morning and hasn't been driven since. Why is it gone lol?
Is there anywhere I can pick one up locally tonight? If anyone has a spare one I'll give you up to $15 for your time. I can't leave my car at my fiancee's over night since it's a private community that will tow non-resident cars. Closest public parking is 4 blocks away. Thanks!
Old 03-18-2008, 02:45 AM
ae13291's Avatar
glad you found the problem man! umm try to shove something temporary in there to get you home man!
Old 03-18-2008, 03:11 AM
GTObsessor's Avatar
I just bought a 1 1/4" - 1 3/8" expansion plug from Auto Zone. Hope this works.
I'm starting to worry where the last cap went? Lol - any chance it could've contracted and gotten sucked into the intake? I mean, there isn't really anywhere else it could've gone... worries me.
Old 03-18-2008, 03:21 AM
6LITEREATER's Avatar
Yeah, I'd be worried about that as well... Pull your TB and take a look with a flash light and mirrors.
It is there SOMEWHERE (in the intake or in the engine bay)... If you don't find it I wouldn't drive it.
I personally think it is time to put an LS6 intake on to be safe (if you pull the intake and don't see it there you know you are good to go)
Old 03-18-2008, 03:28 AM
GTObsessor's Avatar
I was thinking the same thing. Anyone got one for sale for $300 locally?
Old 03-18-2008, 03:39 AM
BeemerZ28's Avatar
time out doesnt that "cap" for the egr look like a football but more rounded? How could that get sucked through the egr hole? Well I am pretty sure you could make one of these and just use lock-tight the next time around with the screws
Old 03-18-2008, 03:45 AM
Not sure what you used but it sounds nothing like what I've seen...
It is unlikely that it (what I am picturing) would fall in BUT if it was the wrong size, had been pushed too far, had loosened up (if it was the type that was an expansion plug) it could fall in.
It obviously didn't happen while he was driving (I think he would have noticed it going to redline) so I really don't see where else it could be besides in the intake
Old 03-18-2008, 03:57 AM
BeemerZ28's Avatar
it soesnt look like one fo these things?
http://www.ws6project.com/user_stor/...99f6df8657f4b1
Old 03-18-2008, 03:58 AM
BeemerZ28's Avatar
not to be rude but 6liter can't sleep, or the nice looking wife keep you up!!! dont ask with me " alcohol, the cause and solution to all of lifes problems"
Old 03-18-2008, 04:31 AM
Nope. You are thinking of the wrong part. It looks like this:
or this:
Old 03-18-2008, 04:32 AM
Worked 9:30am to 1:00am (yes, am to am) yesterday then went out and celebrated a friend's birthday untill about 4am. My sleep schedule is always screwed up...
Old 03-18-2008, 05:42 AM
GTObsessor's Avatar
Expansion plug worked. I'm home now. Couldn't see the old block-off anywhere in the intake so I guess I'm in the clear. Took it up to 2.5k in 2nd and punched it to 5500... not a problem at all. Everything seems to be fine. I'm gonna try to expand the expansion plug a bit more with the help of a friend tomorrow to get the best seal I can. Should work as well as anything else, right? Thanks for the help guys. It's appreciated.
Old 03-18-2008, 05:51 AM
Adriana Lover's Avatar
I've run an expansion plug on mine for about a year. Not a single issue. Glad you found the problem. Finally got a LS1 vette intake w/o the hole so that'll be going on soon.
Old 03-18-2008, 11:40 AM
01black's Avatar
damn that sucks ryan....glad u got it worked out
i'll be pullin my LS6 intake off here real soon.....
Old 03-18-2008, 12:00 PM
camarojunky74's Avatar
i know of an ls6 intake, pm me for the name
Old 03-18-2008, 12:09 PM
BigDaddyBry's Avatar
I love the trial by fire method to figure out if everything's okay.
Old 03-18-2008, 02:01 PM
ae13291's Avatar
hopefully its not in your intake and it dident go past the runners
