drill mod
drill mod
so me and ara did the drill mod on Micaela today. boy was that a bitch.
took us around 4 hours cuz i had to let her cats cool down, and since we both have fat *** forearms, it was a bitch fitting in the little places
man do i feel it better, that 1-2 shift glides right in at WOT now. i luv it.
dave, you have your work cut out for you in may. trust me
i am getting my launch down now to
1 Post
damm i have a big *** bruise on my forearm! lol hey did you double check to see if the cruise control is working? i had to readjust the top switch! ready for a race yet?? on ramp to the 118 w 8 pm dont be late! haha
if i remember correctly the drill mod is primarily for 98-00 cars seeing as 01-02 cars have a slightly less restrictive hydr. line. Of course im just pulling that from the top of my head but im pretty sure i read that at 1 time or anouther.
basically gm put a resriction in the hydr line as to regulate how quickly you can disengage the clutch system as to extend the life of the worthless 10bolt they put behind the t56. I never did the drill mod to my 02, after i upgraded the clutch, pressure plate, and flywheel it was hard enough on that 10bolt. Its only saving grace is i never put a sticky tire on it
basically making the hyd line bigger on the inside increasing flow making less resistance, in some cases before the 01-02 master came out its almost necessary, especially after a few runs, the **** just gets worse, sometimes sticking to the floor,
the drill mod is a quick way to solve most clutch problems in before 01-02, sometimes needed in 01-02
