Western Members CA, AZ, NV, UT, CO, NM, HI
smogable heads and cam
Old 03-21-2008, 03:16 PM
ZMONSTER!'s Avatar
Default smogable heads and cam
hey cali guys, you who have head and cam pkgs that passed smog what all was your combo?
Old 03-21-2008, 03:54 PM
SnakesRslow's Avatar
218-224 .535 .535 114+4
patriot s2 heads
passes sniff emissions with a ton of room to go.
ive seen/heard of 224/228's passing relatively easily
Old 03-21-2008, 04:10 PM
ZMONSTER!'s Avatar
patriot s2 heads
Cool, what are your numbers?
Old 03-21-2008, 04:16 PM
the car made 370rwhp thru an auto and a 3800 converter
it also had Lt's, cats, fast 78, ported tb, lid, etc
Old 03-21-2008, 04:52 PM
travie319's Avatar
Thumbs up
Talk to Ryne @ CMS......I'm sure he can set you up with something!
Old 03-21-2008, 04:55 PM
ZMONSTER!'s Avatar
cool,they a sponsor? website or number?
Old 03-21-2008, 05:43 PM
travie319's Avatar
Yes he's a sponsor!
Ryne Cunningham
Cunningham Motorsports
Specializing In Late Model EFI Performance.
Lake Elsinore, CA
Shop: (951)471-2898
Cell: (951)375-2453
Ryne-CMS@Hotmail.com
Old 03-22-2008, 06:09 AM
ZMONSTER!'s Avatar
anyone else? ttt
Old 03-22-2008, 10:22 AM
MrElectric03's Avatar
Yep...talk to Ryne.
Old 03-22-2008, 12:05 PM
180ls1's Avatar
anyone else? ttt
you can always mix ethanol in your gas and get any car to pass the sniffer even with nasty head cam combo's .
Old 03-22-2008, 12:10 PM
ZMONSTER!'s Avatar
Wait...are you serious? How much!
Old 03-22-2008, 12:17 PM
180ls1's Avatar
it depends on how crazy your combo is i would imagine. My buddy used to do it all the time on his swapped jeep because it would never pass. So he would mix about 1/3 ethanol or so into the his tank when it was low. the tester was like "damn this thing is like a hybrid" and it would pass amazingly. but the molecules are bigger then the gas molecules so it will make your car run leaner. And ethanol has zero emissions so that is why it helps so much.
Old 03-22-2008, 12:48 PM
Soul TKR's Avatar
Ryne put a 224/224 cam in mine with AFR heads.... I figure if I had cats and mufflers i'd pass smog... I know the AFR's are carb legal and with his tune on the cam, it should pass...
put down 446/416
Old 03-22-2008, 01:11 PM
02NHRAtransAm's Avatar
224/224 here
Old 03-22-2008, 04:21 PM
SPLATT's Avatar
i can tell you a TR230 and some Stg 2 LS6s will NOT pass haha. Im sure CMS can set you up
Old 03-22-2008, 07:22 PM
ZMONSTER!'s Avatar
Sweet, thanks all! keep em comin!
Old 03-22-2008, 07:46 PM
BigDaddyBry's Avatar
Although I'm not familiar with the trick, when 180ls1 states to use ethanol, don't go reaching for the expensive pure ethanol (100% EtOH, 200 proof). You want denatured alcohol that's 99% pure ethanol. The other 1% is methanol. There's no tax on this product, so it's cheaper. Also, don't drink it. In high enough quantities, methanol will make you blind. In fact, methanol poisoning is treated using ethanol.
Old 03-22-2008, 08:19 PM
hlaalu's Avatar
so thats the trick then? thats how everyone on here passes smog?
Old 03-22-2008, 09:23 PM
180ls1's Avatar
most people do not know about it but it works well and there is no way to test for it at the smog shop.
Old 03-22-2008, 09:33 PM
hlaalu's Avatar
it would show the car is running lean tho right? so that would pop up a ses light. what if u just clear all the codes right before you let the guy take your car?
Quick Reply: smogable heads and cam
