Western Members CA, AZ, NV, UT, CO, NM, HI
Fuel PUMP bad?
Old 06-22-2008, 05:38 AM
COPSS's Avatar
Default Fuel PUMP bad?
today while driving with my girl I noticed that my camaro was making a whining noise coming from the back. so I pull over and check to see what it was and my fuel pump was whining really loud, my cAR HAS ONLY 94,000 MILES DOES MY PUMP NEED TO BE CHANGED? and what pump should i get?
Old 06-22-2008, 06:01 AM
Datzneat's Avatar
Might have gotten it clogged. Don't know. Maybe post in the fuel section. Any planned upgrades for the future? If so racetronix if not I bet you can pick up a used stock one for cheap.
Old 06-22-2008, 11:18 AM
383lt1impala's Avatar
get a walpro 255. or the racetronix kit.
Old 06-22-2008, 02:58 PM
COPSS's Avatar
it runs good but Think id rather replace it with a good fuel pump instead of a oem! What oyher pumps are good besides racetronics and walbro 255?
Old 06-22-2008, 03:03 PM
the walpro 255 lol. its cheap and good.
Old 06-22-2008, 03:08 PM
94'BLKBRD's Avatar
You mean Walbro 255
Old 06-22-2008, 03:15 PM
COPSS's Avatar
yeah walhoe 269!lol it sucks ur fuel real good
Old 06-22-2008, 03:19 PM
Wicked_muscle's Avatar
I'll come out and help you cuz I might need to do it soon.
Old 06-22-2008, 04:45 PM
COPSS's Avatar
it will have to be in a few weeks im getting the gn out the shop real soon.
Old 06-22-2008, 06:53 PM
Jeremy 92 RS's Avatar
That doesn't mean it is automatically bad. I have even heard brand new fuel pumps make some strange noises. Try changing the fuel filter and adding some Chevron fuel system cleaner or Seafoam into the fuel for the hell of it. Cheap reassurance for around $30 or so.
Sounds overkill. The stock fuel pump is capable of over 400whp. This is assuming COPSS is mostly stock.
Old 06-22-2008, 07:04 PM
Almostryan3's Avatar
Be prepared to cut up your car or do a lot of work. I would just cut the trap door.
And overkill? Fuel is very very important, I wouldn't want to worry about even coming remotely close to running out of pump.
Old 06-22-2008, 07:19 PM
BigDaddyBry's Avatar
I have the Racetronix kit if you're interested. Bought it a few months back during a sale, planning on needing it for nitrous, never got nitrous.
Old 06-22-2008, 08:39 PM
COPSS's Avatar
well the car im mostly stock of course k&n cold air intake,wires and flowmaster. i have not changed the fuel filter yet so thats next. Thanks for the help it just seem strange that my pump will go out this early. my 94 impala recently went out and it had more miles. how much for the pump BRY?
Old 06-22-2008, 08:54 PM
-98-Z28-Darkness-'s Avatar
i been hearing it that buzzing sound too.... starts and stops evry now and then usually in park...i am gonna change the fuel filter.....
everything runs good been hearing it for about 6-8 moths now my car has 42,XXX miles so im just going to do a full seafoam before i cange the filter
o might be your spare tire or something in there as well. some rattaling
Old 06-22-2008, 09:19 PM
I noticed you have a 98, the pump is for 99-02s (plastic tank), sorry.
Old 06-22-2008, 10:55 PM
Datzneat's Avatar
How much Bry? and does it come with the harness?
Old 06-22-2008, 11:49 PM
ss.slp.ls1's Avatar
A Walbro 255lph pump is more than capable of supporting high horsepower motors, let alone a stock car. I've done the install (trap door method) on my 97 SS. It's simple, I'f its similar with your car, I'll show you how.
Old 06-23-2008, 01:51 AM
If you like hackjobs, then go ahead and cut the car. Everyone has their own preference.
And thanks for stating the obvious. If he does have plans for serious mods in the future, then it is always good to be prepared, but too much fuel in the mean time on a mostly stock is motor is not going to help his performance.
Old 06-23-2008, 07:47 AM
ss.slp.ls1's Avatar
Fuel pressure is regulated by the fuel pump, actual fuel delivery is controlled by the ECU via pulse width of the injectors, so regardless of what pump you have, you will still be delivering the same amount of fuel to a stock engine, but the Walbro pump will be capable of delivering more fuel when fuel needs are increased.
Old 06-23-2008, 07:13 PM
Exactly. If he ever has thoughts about modding more then he won't have to worry about running out of pump for a long time. IMO better safe than sorry. Also I have seen the trap door done very cleanly. TunedbyTad did a really nice trap door cut out. Also Bowtierodder had a really nice trap door set up. Not all of them look like ****.
Quick Reply: Fuel PUMP bad?
