Western Members CA, AZ, NV, UT, CO, NM, HI
FS: LS1 Camaro Nitrous kit
Old 06-24-2008, 01:27 PM
Ruckus46Gt's Avatar
Default FS: LS1 Camaro Nitrous kit
Selling my nitrous set up. The set up is 4 months old, the new bottle has been filled one time. Kit has had 4 bottles go through it. The set up is
-HSW wet 78mm plate kit
-HSW Revolution bottle heater
-HSW Purge kit
-Nitrous Outlet/Trick Single Stage Window switch with TPS sensor activation
-FPSS with fittings
-860 spare tire mount
-HSW custom 8an stainless steel line for blowdown tube
-8an bulkhead fitting
-HSW ash tray switch panel
All togther everything is just over 1200 dollars. Selling the kit for $550 located in Glendale, AZ. I am not looking to ship pick up only
here is the kit
pics of the kit installed
As you can see there is extra purge line, roll of unused wire, and all wire lengths are about 1/2" shorter then they came due to cutting where the connectors were. Also teflon paste was used not tape, tape can come off and clog the system.
Old 06-24-2008, 03:03 PM
camarojunky74's Avatar
wow great deal and a nice kit, if only i had the extra cash, good luck with the sale, i know this will be gone come friday for sure
Old 06-24-2008, 04:16 PM
james562's Avatar
Sweet price this should be gone in a heartbeat
Quick Reply: FS: LS1 Camaro Nitrous kit
