ls3 build
ls3 build
any body have any good sugestions on harden internals for my ls3? i havent done a whole lot of research on it i just know i wanna do it. my goal by the end of this summer have it in my camaro =)
LS1TECH Sponsor
depending on your power goals , but up to 1000 hp , simple stock crank stock displacement or callies 4.00 crank (4.100 and larger is not suggested because the sleeve length on the stock ls3 is only 5.6" and with longer then a 4" stroke crank the oil will usually come out of the sleeve at the bottom of the stroke causing oil consumption issues usually), manley/k1 rods, and nice wiseco pistons (4.065" bore), would definitely suffice
