Western Members CA, AZ, NV, UT, CO, NM, HI
wat size mickey thompson
Old 07-02-2008, 02:31 PM
SVTBAIT's Avatar
Default wat size mickey thompson
What size mickey thompson drag radial should I be running on a 17 inch bogart? Is it 315 50 17?
Old 07-02-2008, 02:38 PM
krazy4's Avatar
Depends on how wide the wheel is.
If it is a 10 or 11 wide should be good to go 315s.
Old 07-02-2008, 02:53 PM
allblacksrt4's Avatar
205/35/17. lmao
Old 07-02-2008, 03:01 PM
SVTBAIT's Avatar
I Think Its 17 By 8
Old 07-02-2008, 03:24 PM
krazy4's Avatar
275/xx/17
Old 07-02-2008, 03:26 PM
SVTBAIT's Avatar
I Want To Run A 315 Tho..
Old 07-02-2008, 04:37 PM
02NBMWS6's Avatar
then you need a 10" or wider wheel. 8" is for 245s
Old 07-02-2008, 05:01 PM
Stroker396@APF's Avatar
Ya I have 315 BFG's on a 9.5 and they overhang a bit to much for that rim. But you can def get bigger than a 245 on an 8" rim, 275 for sure maybe a 285
Old 07-02-2008, 06:45 PM
Almostryan3's Avatar
I run an 11.5 on a 8"(maybe 8.5?) snowflake rim and it doesn't overhang too bad.
Old 07-02-2008, 06:50 PM
SVTBAIT's Avatar
So I Should Get 16 Or 17 By 11 ?
Old 07-02-2008, 07:25 PM
well if its a 17" rim there is your answer...
Old 07-02-2008, 07:28 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
315/50/17 is going o be a TALL tire.. thats 29" tall
I have 315/60/16s on my TA and they are HUGE. You sure it's not a 315/45/16 or 315/45/17?
Old 07-02-2008, 07:45 PM
SVTBAIT's Avatar
Yea I Think Its A 315 45 17
SVTBAIT's Avatar
DO U HAVE PICS OF YOUR SET UP THANKS
Old 07-02-2008, 07:47 PM
02NBMWS6's Avatar
dude, 315/45's arent going to be much smaller. If you want it to fit on your vette you should probably get a 315/35 or maybe you could squeeze a 315/40 on
Old 07-02-2008, 07:49 PM
02NBMWS6's Avatar
315/40 is 27" inches tall, I doubt you could fit that on your vette. 315/35 is probably what you'll need
Old 07-02-2008, 07:54 PM
SVTBAIT's Avatar
So 315 35 17 It Is Thanks For The Help
Old 07-02-2008, 08:59 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
here is a small one
they fill out the entire fenderwell and are tucked up underneath they are just a bit over 30" tall.
Old 07-02-2008, 09:05 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
315/45/16= 27, it should fit
stock c6 z06 fit 26" tires without a problem.
lol... they dont even make a 315/45/17, i fot it mixed up with 295/45/17 below it
Old 07-02-2008, 09:56 PM
1320 killer's Avatar
Quick Reply: wat size mickey thompson
