Western Members CA, AZ, NV, UT, CO, NM, HI
Maf
Old 07-12-2008, 08:17 PM
mattyboy80's Avatar
Default Maf
Anyone got a maf for sale? I f'd mine up lastnight.
Old 07-12-2008, 08:30 PM
ss.slp.ls1's Avatar
I assume you already tried to clean it to no avail?
Old 07-12-2008, 08:32 PM
mattyboy80's Avatar
ITs a different story than that...
mattyboy80's Avatar
You goin tonight? Ill tell ya there
Old 07-12-2008, 08:35 PM
ss.slp.ls1's Avatar
I'll be there.
Old 07-13-2008, 01:46 PM
mattyboy80's Avatar
Thanks for the help lastnight man. Really appreciated.
Old 07-13-2008, 03:37 PM
180ls1's Avatar
01somss has one for sale check the western classifieds i believe, it is the 85mm one too.
Old 07-13-2008, 08:17 PM
ss.slp.ls1's Avatar
No problem.
Old 07-13-2008, 08:25 PM
hlaalu's Avatar
i have an slp maf i dont need, i switched back to my stock one after my header install
Old 07-13-2008, 10:41 PM
SUCK MY SS's Avatar
post up what the problem and solution was.... may help other western forum members!
Old 07-14-2008, 02:22 AM
fast01z28's Avatar
well i looked at his maf and it seems ok. we finished porting it. i think its the IAT valve in his TB. he cleaned it when he put in his ported tb and it might not be gapped correctly. the car runs fine other than the high idle.
Old 07-14-2008, 03:02 PM
hlaalu's Avatar
off topic but did you guys notice a difference in performance after porting the stock maf?
Old 07-14-2008, 04:06 PM
mattyboy80's Avatar
Its a little hard to tell. I also put in a ported tb and a lid. There is a big difference though.
Dave the exhaust will be here this week. And I am going to look at the amp tonight. Did you look up the gap for the IAT?
Old 07-14-2008, 05:55 PM
fast01z28's Avatar
measure the distance from the flange (or gasket mounting sirface of the IAC valve) to the tip of the pintle. If the distance is greater than 1 1/8 inch, reduce the distance by applying pressure onto the pintle to retract it. Try some side-to-side motion in the event the pintle binds.
try that.
I also sent Granatelli an email to see how much a maf would be. ill let you know what he says. I also asked him about something for me.
Quick Reply: Maf
