Western Members CA, AZ, NV, UT, CO, NM, HI
I blew my clutch at qualcomm.
Old 09-06-2008, 04:54 AM
01SOMSS!'s Avatar
Default I blew my clutch at qualcomm.
what a night. i got my license back and went down to qualcomm with new rubber and came back needing a new clutch.sucks! hopefully i can get fixed.dont know if I'll make the irvine meet.
Old 09-06-2008, 04:56 AM
DF
DF's Avatar
Are the events at the Q for autocross of dragging?
Old 09-06-2008, 07:56 AM
redracer1's Avatar
Dude, that sucks ***!!
WTF Hop in Mayra's Z and lets go!!
Old 09-06-2008, 08:22 AM
Phantom06's Avatar
That sucks!!! What kind of times were you running with the new rubber?
Old 09-06-2008, 09:32 AM
SSMOKIN_Y2KSS's Avatar
He probably ran about a 15.2 @42mph cause of all that chrome
Old 09-06-2008, 09:47 AM
Phantom06's Avatar
He do keep it clean tho. hahaha
Old 09-06-2008, 10:41 AM
jsteele90's Avatar
nah they 10s but i keep em clean
Old 09-06-2008, 10:43 AM
camarojunky74's Avatar
i just spit orange juice all over my comp thats pretty funny.
Old 09-06-2008, 12:00 PM
Soul TKR's Avatar
what kinda clutch did you have?
what you gonna get?
Old 09-06-2008, 12:21 PM
ae13291's Avatar
my clutch slipped like a bitch last night too
Old 09-06-2008, 12:31 PM
96modgt's Avatar
That sucks, sorry to hear that. I think ive met you down in San Marcos a couple of weeks back.
Old 09-06-2008, 12:37 PM
01SOMSS!'s Avatar
well it might be a hydraulic problem. i'm no mechanic.here's what happened. i did 2 passes.last run I hooked first gear good and as I tried to hit second. .I couldn't shift into it. i had to force it in.then it locked me out of 3rd. i pulled over in neutral.i came to a complete stop and then tried shifting, but my tranny wouldnt go into any gear at all.I shut the car off and i was able to go into gears with the car off.when i started the car in 1st. the cars idle drop to 300. then as i shut the car off i tried it again then the car would stall in 1st. it would shoot forward and stall. what do you guys think?
Old 09-06-2008, 12:41 PM
ae13291's Avatar
sounds like the pressure plate is sticking to the clutch, could be from the fingers on the pressure plate or it could be the fact that it got real overheated. try the easiest thing, bleed the hydraulics
Old 09-06-2008, 01:08 PM
Banned Village Idiot
LS1BLKSS's Avatar
damn that sux luis... do you still have the stock clutch???
Old 09-06-2008, 01:12 PM
it is deff a hydraulic problem, dont try bleeding it get a mighty vac and some new fluid try that, if no luck your going to need a new master
Old 09-06-2008, 01:46 PM
geovett's Avatar
Wink
do a swap.........to Auto........................G/L L.........Hail to the SOM!!!
Old 09-06-2008, 07:25 PM
camarossls12001's Avatar
I have had the same problem with mine twice and its the clutch i tried swapping the master no improvement, then tried the LS6 clutch and slave which fixed it the first time then the damn freeze plug on the back of the crank started leaking and soaked my clutch so had to redo the clutch again went with the RAM Powergrip now the throw out bearing needs to be changed
Old 09-06-2008, 07:31 PM
01SOMSS!'s Avatar
sucks!
Old 09-06-2008, 08:31 PM
m6ttop's Avatar
what did u run on your 1st pass?
Old 09-07-2008, 01:31 AM
180ls1's Avatar
did you see that v8 miata there that thing hauled ***. Your car looked strong but i was not there too long so i guess i missed it when you were having problems.
Quick Reply: I blew my clutch at qualcomm.
