Western Members CA, AZ, NV, UT, CO, NM, HI
E85 did not help smog......
Old 10-02-2008, 04:19 PM
djsanchez2's Avatar
Default E85 did not help smog......
Ok fellas i failed the first time, used E85 the second time and still failed whats the deal?
Old 10-02-2008, 04:26 PM
camarojunky74's Avatar
you need to adress the problem, not try to put a bandaid on it, what is done to the engine? are you running aftermarket cats, and the best question is put of your readout, so i can see what the car is doing
Old 10-02-2008, 04:27 PM
OEM_TA's Avatar
Depends on what items it is failing on.
List the readings that failed.
Old 10-02-2008, 04:52 PM
allblacksrt4's Avatar
its those cheap cats
Old 10-02-2008, 08:32 PM
FearTheDeer's Avatar
cant you just lean it out?
Old 10-03-2008, 12:38 PM
ae13291's Avatar
its your cats
Old 10-03-2008, 01:20 PM
so he can just fail the nox?
Old 10-03-2008, 02:03 PM
djsanchez2's Avatar
Failed NOx and CO. But it's getting taken car of today Then i don't have to worry bout it for 2 more yrs
Quick Reply: E85 did not help smog......
