tips on how to lower my 60ft.
any advice. my 60's suck. i've been going to the track for the last month.
my car is a full bolton car. no cam or heads.I'm running bfg's Dr's 275x40?x17's and most of my 60's are 2.2's. i lower my tire pressure from 22psi-16 psi. i launch at 3krpm.any advice?
I just got some 16'' mt et streets that i'll be using soon. so it should hook a bit better. do you guys think it safe to run them on my car? kinda scared..thanks guys!
Second, you'll probably be ok with slicks, but I'd being a trailer to the track, cause if you're on a stock rear, it's not if, it's when.
i ussually burn out for 5 Mississippis(luke method ) and lauch at 3k rpm i slip it a bit apperantly not enough.a lil of a slip and dump. do you guys think I'll be ok on the Et's?
LCA's are next
LCA's are next
I know CamaroJucky Is going to jump on me about this b/c I forget everytime I dont know **** about suspension but I would recommend Relocation brackets regardless of your car being lowered. They help with the angel of the control arms and increases pressure on the rear wheels. Disconnect the front swaybar end link to help with weight transfer. Then Control arms. From there just practice "A LOT" on slipping the clutch. I have pulled a 2.0 Flat on street tires. The time in my sig. where on ET Streets and I was clutch dumping at 3600rpms and bogging off the line but still pulled my best time like that . To much tire.
I would sau Do a 3300-3800rpm Clutch Slip. So about a 2-4 second burnout to simply get the water off the tires. Drag Radials dont technically need to be heated up like Slicks do.
you just have to learn your car its deff trial by error, no stress john force didnt wake up one day hitting perfect r/t's. for your application which is very similar mine, you have to find the balance of clutch and gas, to much of either 1 will significantly hurt your 60's its just something you have to work on. what will help no matter what track your going to is noting info down on each time slip, rpm you launched at, the amount of slipping the clutch you did and or how much you think you spun or bogged,
ex
1.909 60'
i would describe mine like this
3500rpm
slipped the clutch but let go of it too early and bogged out of the hole.
ex 2
1.850 60'
4000rpm
slipped the clutch but still spun a little no bogging
ex3
1.809 60'
4250 rpm
slipped the clutch hard, barely spun no bogging
this is what i do every time i make a pass as well as note tire pressure after each pass, and write that down as well, helps find what your tires like and what your car likes
hope this helps
ex
1.909 60'
3500rpm
ex 2
1.850 60'
4000rpm
ex3
1.809 60'
4250 rpm
hope this helps
True, so if your good with operating two pedals with one foot preload the car a bit, not too good on the clutch since you will be slipping it to preload it but when you get good at it you can start preloading on the second amber so its not slipping for too long.
Thats way too long to heat up a drag radial. You just need to clean them off and warm them up a bit, too hot is just as bad as a cold tire.
60' times, not R/T, nothing to do with each other. Stock power is enough to break a 10 bolt...
true but when you get even better you stop lifting off the gas while shifting further killing the life expectancy for the clutch and or the rear
