94 Z28 roll cage**nitrous**th-350
1994 Z28 Camaro 12.27@112mph
*** WILL TRADE FOR HARLEY!!!!***
* custom bent 6pt roll cage by mickeys chassis works. metal was sanded down and painted with clear coat only.
*NOS super power shot (150 hp) i have plate that i can include to make a traditional wet kit. (plate installs behind throttle body)
*th350 trans. ptc 3k stall. (factory cam so no need to giant stall) aftermarket tranny cooler with -an fittings on the cooler and on the tranny. all new 3/8" hardlines ran for tranny. custom round tube crossmember with torque arm mount. B&M quicksilver shifter mounted inside factory console. bluementhals 3" steel drive shaft wtih 1350 u-joints.
*bmr boxed sub frame connectors. welded at the front and bolted in the rear.
*glasstek 4" cowl hood. shift light mounted inside of cowl.
*pacesetter long tube headers. y-pipe. into 3" dynomax bullet dumped.
*two factory front seats cut for 5pt harnesses.
*pw, pl, ps, a/c, heat, all there. i was drag racing this car. but still perfectly capable of being driven ANYWHERE.
* paint on front bumper has started "spidering" couple small hail dings on rear quarters
* i will include the 15X8 centerline telstars with the car if i get a reasonable offer.
i do have all rear seats and all seat belts to go with the car. as well as factory z-28 exhaust with tips, and 2-16" firebird wheels with et-streets mounted on them.
im sure i have left something out of this posting so please dont hesitate to call and ask questions!!
405-596-0876-cory
405-596-0876-cory
