modded 1999 camaro z28
I have a 1999 Z28 camaro with just over 100,000 miles on the odometer. I was wondering what I should be able to get for it. It has a long list of mods.
The shortblock has a stock crank, eagle rods, and mahle pistons. It also has a arp main stud kit. It was rebuild about 1500 miles ago with new cam and main bearings.
Ls7 lifters
lingenfelter high flow oil pump
comp cam double roller timing chain
hardened pushrods
231/237 .598 .596 cam
243 patriot heads with the double .650 valve springs
typhoon 96mm intake and 92mm tb
slp lid
k&n filter
kooks 1 7/8" LT headers
arp 12 point head stud
cold fusion nitrous kit
Spec stage 3 clutch
Loudmouth exhaust
moser 12 bolt with 4.30 gear.
15x10 draglight copy rims
325/50/15 ET streets in rear
I am just trying to get an idea of what its worth. Thanks!
Ls7 lifters
hardened pushrods
slp lid
k&n filter
Spec stage 3 clutch
Loudmouth exhaust
