2002 WS6 - Lots of mods
Old 08-31-2011, 10:30 AM
MetallicaMatt's Avatar
Default 2002 WS6 - Lots of mods
I'm curious to see what a good asking price would be for this car, and what it would likely sell for.
Thanks!
2002 Trans Am WS6
Black, manual Transmission
Less than 22,000 miles
**I’m posting this a little early, as I still need to get a front end alignment done on the car, since installing the new front suspension**
The car has been babied its entire life. I am the 3rd owner. It was bone stock except for the cat-back exhaust when I purchased it.
It was a Sunday driver up until that point. I have only put a few thousand miles on it, since purchasing the car in 2005-2006. I've spent most of my time modifying the car. The reason for selling is that I've been presented with the opportunity to purchase a car that’s been in my family for a long time, one of those once in a lifetime opportunities.
I have a lot of money invested into this car, but I want to have this car sold before winter, so I can get the Model A.
I have all of the original parts off of this car, including the factory hood. You will need a full size pickup to hold everything else.
This project has been very enjoyable and I hate to sell the car, but it's a once in a lifetime opportunity to purchase the other vehicle.
You can see that most of the modifications have very little miles. Much of the modifications have been done over the past year and have little to no miles on them. I just don't have the time to finish things quickly or drive the car anymore.
No joy rides of any sort. The new clutch only has less than 10 miles on it right now, so you can't get on it, as it is still in the break-in period. Spec recommends a minimum of 500 miles break-in period of city driving.
Car must be paid in full with all funds cleared before I will release the title.
Would make a great car for someone looking for a street/strip vehicle, or looking for a very clean strip car.
Things to note, in case anyone is skimming the add:
Power steering has been removed and replaced with a Spohn manual steering rack.
Air Conditioning has been removed (Was in working condition, never used it, decided to clean up the engine bay and reduce weight)
ABS has been removed (same reason as A/C)
The body is in excellent condition. No dings or dents. Little to no scratches anywhere on the car - it's just very dirty, from being stored most of it's life.
Thank you for looking and feel free to ask questions.
KBB Value: $16,000
Modifications added: $17,000+
Asking: ??
(You're saving $xx,xxx, not counting labor!)
Interior:
Embroidered Headrests
CNC Machined Pedals
Wolfe 6 point cage
Exterior:
Superhawk hood (#50 of 50)
Engine Bay:
Texas Speed Magic Stick v3 cam (Less than 4,000 miles ago)
Hooker Super Comp Stainless Steel Long Tube Headers (Less than 4,000 miles ago)
Catalyic Convertors Removed
Hooker Y-Pipe and Cat-Back Exhaust
Meizer Electric Water Pump (less than 50 miles ago)
Removed Power Steering, ABS, Air Conditioning (less than 50 miles ago)
BMR Alternator Relocation Kit(less than 50 miles ago)
TCI Rattler SFI Crank Pulley (less than 50 miles ago)
ARP Crank Pulley Bolt (less than 50 miles ago)
Violant Cold Air Intake
Optima Red Top Battery
Spohn Tublar K-Member (less than 50 miles ago)
Spohn Tublar A-Arms (less than 50 miles ago)
Spohn Manual Steering Rack (less than 50 miles ago)
Poly Motor Mounts (less than 50 miles ago)
QA1 Adjustable Shocks and rear springs (less than 2,000 miles ago)
Walbro 255HP in tank fuel pump
ARP Wheel Studs
Transmission:
Viperized - completely rebuilt with Viper internatals, input & output shafts etc. (Less than 2,000 miles ago)
Pro 5.0 Shifter
Spec Stage 2 Clutch (less than 50 miles ago)
New Throwout bearing, pilot bearing, speed bleeder (less than 50 miles ago)
Transmission Back:
Spohn Torque Arm with drive shaft safety Loop (less than 1,000 Miles ago)
1,000 HP Driveshaft with Cyro dipped U-Joints (less than 2,000 miles ago)
Currie 9" Rear End, 3.90 Gears with Detroit Locker
BMR Tublar Sub Frame Conenctors
BMR Single Adjustable panhard rod
Extras:
BMR Double Adjustable LCAs – new in box
Full set of brand new cyro treated rotors and Hawk ceramic brake pads – new in box
California Car Cover, very nice cover
**Every part that was removed from the car has been kept!! The only item I do not have, is the original cat-back exhaust. This was gone before I got the car**
QA1 Shocks and front springs 950
Walbro 255HP Fuel Pump 130
ARP Wheel Studs 100
California Car Cover 400
Pedals 130
Alt Relocation Kit 130
Wolfe 6 point cage 510
Superhawk hood (#50 of 50) 2000
Texas Speed Magic Stick v3 cam 850
Hooker Super Comp Stainless Steel Long Tube Headers 760
Hooker Y-Pipe and Cat-Back Exhaust 600
Meizer Electric Water Pum 550
BMR Alternator Relocation Kit 130
TCI Rattler SFI Crank Pulley 250
ARP Crank Pulley Bolt 26
Violant Cold Air Intake 300
Optima Red Top Battery 175
Spohn Tublar K-Member 700
Spohn Tublar A-Arms 815
Spohn Manual Steering Rack 700
Poly Motor Mounts 60
Viperized - c 1000
Pro 5.0 Shifter 180
Spec Stage 2 Clutch 650
New Throwout bearing, pilot bearing, speed bleeder 200
Spohn Torque Arm with drive shaft safety Loop 540
1,000 HP Driveshaft with Cyro dipped U-Joints 400
Currie 9" Rear End, 3.90 Gears with Detroit Locker 3000
BMR Tublar Sub Frame Conenctor 155
BMR Single Adjustable panhard rod 100
BMR Double Adjustable LCAs 200
Full set of brand new cyro treated rotors and Hawk ceramic brake pads 600
Total 17291
Old 09-01-2011, 09:00 AM
NC01TA's Avatar
OMG!! Not another low mileage heavily modded car!! You must read some of the other posts here for your own benefit.
First off, get that Model A so you won't regret it the rest of your life. Do not pass it up if you want it real bad. Get a loan if necessary.
You have an incredible low mileage car there except for the typical panel crack. After that excellent write-up you said it was 'very dirty'. For heavens sake, don't ever write that. Wash and wax it and make it pop like your pictures.
KEEP THE CAR. You won't get close to what you have invested in it. It isn't happening right now in these times. You will even have trouble getting just the KBB value without any of the mods cost. Shocked?? I bet you are but you will find out the hard way unless you are very fortunate to find that one buyer that wants all that you have done, and has the big bucks to pay for it. Tough, tough younger market, a market with limited resources. Perhaps when the economy gets better there will be more of an active market but if you sold this car for more than KBB's $16,000 value I would would be quite surprised, and pleased to hear at the same time. Best of luck to you in your acquisition of the Model A.
Old 09-01-2011, 01:51 PM
TransAmDemon2000's Avatar
I agree ^^^^^^^^ love the hood tho
Old 09-01-2011, 07:29 PM
Actually, I just took those pictures. So, that is my idea of "very dirty".
I'm a Adam's Polishs product kind of guy, so it's dirty to me
but thanks for the post!
Old 09-02-2011, 08:11 AM
NC01TA's Avatar
You are quite welcome. OK, I get the 'humor' now. Sometimes it doesn't come across well in posts, or I'm just a little slow. Best of luck with everything.
Old 09-29-2011, 07:55 PM
Z-28's Avatar
I would say $14k obo. Cam only motor, no a/c, no power steering, no ABS, no dyno sheet.
Old 10-04-2011, 05:19 PM
1972camarols1's Avatar
Maybe 14k
Quick Reply: 2002 WS6 - Lots of mods
