What its worth?
What its worth?
I know theirs tons of threads out there discussing this but I really haven't found a good answer to my question. What is my ls1 short block worth? It has 80,000 miles on it and it spun a bearing. What do you guys think its worth as a short block and as a long block with stock heads and comp .660 lift springs and chromeoly pushrods? Thanks in advance for any help I can get.
I would say a lot depends on your location, they seem to be worth more in some places then others. But from what I have seen I would say a few hundred dollars, as I have seen a few complete pull outs in working condition with all accessory, wiring harness, and PCM going in the 1000-1200 range. Sadly LS1's are not worth what they were a couple of years ago. But you could always start higher and go down if needed
