2002 SS Camaro
2002 SS Camaro
I am looking to sell my long time love. It makes me sad, but I am curious as to what she is worth. I am the 2nd owner of this car. When I purchased it in Aug 2003 it had just under 20k miles. Caught the mod bug in 2005 and and started the project. The motor now has about 35k miles on it. I daily drove this car for 3 years (2009-2012) without a problem. It has been garaged over the last year and just hasen't driven as much as it should. I fire it up once a month, and is as reliable as ever. KBB says $10500, with all of the mods I figured I could price it at around $14000. What do you think?
Exterior: 8.5/10
-It has minor dings and scratches from the daily driving. Over all the body/chassis is straight. Some curb rash as well.
Interior: 8.8/10
-Driver side seat has minor leather cracking. Everything else is clean. SS embroidered floor mats.
Ran it once at the track on street tires. It went 12.6@114 (fastest trap was 118).
Parts below:
2002 Chevrolet Camaro SS
Milage: 68861
• 346ci short-block
o Stock LS1 aluminum block
o Stock Crank
o Scat forged rods
o JE forged pistons w/valve relief
• MTI Stage 2r heads
o Milled .030
o Manley dual valve springs
o Titanium retainers/keepers
o Bronze valve guides
o Hollowed out valves
o Harland Sharp Rockers
o Head flow numbers below
• MTI G1 cam
o Duration 228/232
o Lift .588/.575
o LSA 113
• 10.6:1 compression ratio
• Ported LS6 oil pump
• Port and polished LS1 TB
• LS6 Intake manifold
• SLP CAI
• 30# SVO injectors
• QTP 1 ¾ HVMC headers & Catted X pipe
o Custom bolt in test pipes
• Texas Speed and Performance True dual exhaust
o 18” bullet mufflers dumped @ the axle
• Koni 4/4 Shocks
• Strano Springs
• Strano 35/22sway bars
• BMR Torque Arm
• UMI Panhard Bar and Lower Control Arms
• Spec Stage 3x Clutch
• Hurst short throw shifter with Lou’s Short Stick
• Moser 12-bolt
o 31 Spline Axles
o 3.73:1 Gear ratio
• American Racing Torq Thrust II’s
o Rears :17x11 wrapped in BFGoodrich KD 315/35 ZR17s
o Front: 17x9.5 same in 275/40 ZR17s
• Tuned by Rick @ Synergy Motorsports in Fremont, CA
• 447RWHP/430RWTQ on 91 octane
*Head flow numbers:
Lift IN - EX
.100 - 65/55
.200 - 131/98
.300 - 189/141
.400 - 231/175
.500 - 265/199
.550 - 276/211
.600 - 277/218
Exterior: 8.5/10
Interior: 8.8/10
Parts below:
Milage: 68861
• 346ci short-block
o Stock Crank
o Scat forged rods
o Milled .030
• MTI G1 cam
o Duration 228/232
o Lift .588/.575
o LSA 113
• SLP CAI
• 30# SVO injectors
• Koni 4/4 Shocks
• Strano Springs
• BMR Torque Arm
• Moser 12-bolt
o 31 Spline Axles
o 3.73:1 Gear ratio
*Head flow numbers:
Lift IN - EX
.100 - 65/55
.200 - 131/98
.300 - 189/141
.400 - 231/175
.500 - 265/199
.550 - 276/211
.600 - 277/218
Please read other posts here in this section about mods and how it affects the value of the car. No need to keep repeating the same thing over and over. If KBB says $10,500 in your zip code, that will be the correct asking price range, maybe.
thanks dude, that was extremely helpful.
All I was looking for, in your opinion, does the price seem like a fair deal. I understand how mods affect asking price, if I didn't I would assume the car is worth $23k.
No dude! $14k is too much. Sure that $14k price is fair, the car is worth over $20k just like you said. Ask whatever you like but when phone doesn't ring, don't be surprised. Very few are paying anything for mods. Nothing, NADA, ZIP!! You didn't read any posts like I suggested, did you?
