99 Silverado Z71
99 Silverado Z71
Extended cab, short bed, 3 door. The 99-02 body style.
Good-
-Truck runs awesome. I daily drive it on a pure highway commute.
-4wd works great (push button)
-A/C and heat work great
-Power seats work great, power windows work great
-265k on body
-only 30k on 5.3 motor, has perfect compression and holds over 40 psi oil pressure at a hot idle.
-about $6-7k was put into the truck two years ago, have all paperwork
-Trans shifts great
-Doesnt burn/leak any oil
-Step bars, toolbox if buyer wants it
-285 BFG tires with 17" tahoe wheels, probably 75-80% tread. Lots of life.
-Hitch
-Bed liner
-New battery
-Have a factory CD player to go with it.
Bad-
-Dent above driver side wheel well. Previous owner did it, not sure how.
-Rust spot on drivers side rocker under cab. Passenger side has a very small spec of the beginning stages, but you cant see it unless you get close.
-Clearcoat on hood and roof is a bit faded. Hood was actually spraypainted what looks to be over green.
-Some small pieces on interior dashboard trim are peeling
-Some of the radio ***** are missing (bass, treble). Ive had a couple of these trucks and they've all done this. Still completely functional...you just turn the metal **** instead of the plastic covering.
-Front passenger side part of bumper is cracked a couple inches.
-Front driver side panel next to hood is slightly damaged, was a deer.
Ive taken the truck on several long trips and its been great. Body has a lot of highway miles, so there are definitely squeaks and rattles, but I wouldnt hesitate to drive it anywhere.
Good-
-265k on body
-Trans shifts great
-Hitch
-Bed liner
-New battery
Bad-
