What You Think About These Wheel And Tires?
Old 04-13-2008, 12:43 PM
powers84's Avatar
Default What You Think About These Wheel And Tires?
WHAT YOU GUYS THINK IT GOING ON A WHITE 98 TA? WILL THEY FIT AND WILL I NEED ANYTHING ELES?
THANKS
Shopping cart
Your cart contains:
15" x 7" Street Lite Wheel
Bolt Circle: 5 x 4-3/4"
Rear Spacing: 4-1/2"
Part Number # 135-RS035706145N
This item will ship Monday.
$229.99 EA
TOTAL $459.98
------------------------------------------------------------------------- 15" x 10" Street Lite Wheel
Rear Spacing: 7-1/2"
Part Number # 135-RS035106175N
$244.99EA
TOTAL $489.98
Hoosier Quick Time DOT Drag Tire
Tread: 8"
Part Number # 522-17050QT
This item is temporarily out of stock. The expected date it will ship is 05/08/08, if your order is placed today.
$157.99EA
TOTAL $315.98
Tread: 10"
Part Number # 522-17125QT
$171.99 ea
total $343.98
Update
Subtotal: $1,609.92
Old 04-13-2008, 01:01 PM
Leedogg's Avatar
15x7? from what I've read- no way that'll fit on the front.
Old 04-13-2008, 03:02 PM
sixvi6-camaro's Avatar
Are these going on an LS1 brake car? Its been proven that the rears will not clear Ls1 brakes no matter what you grind. also 7" wide on the front? I don't think those will clear the brakes either but that has not been proven yet.
Old 04-14-2008, 05:00 PM
powers84's Avatar
so whats a good setup i want to be able to DD i only drive 8 miles a day, are prostars better and everything is ls1 on my car its a 98 no mods in that department
Old 04-16-2008, 01:27 PM
powers84's Avatar
thats some bulls@it i cant belive they made them and they dont fit ls1's thats crazy
Old 04-16-2008, 01:49 PM
95GreenZ28's Avatar
You can get the summit stars if you want to save money over prostars as well
Old 04-20-2008, 05:09 PM
powers84's Avatar
if i went with the summit star what size should i get i was thinking 15x10 with 7.5 bs and something in the middle up front so i can DD. i only drive a few miles a day
Old 04-20-2008, 05:11 PM
95GreenZ28's Avatar
You would have to get 15X8 backs cause they dont have them in 10s.
Old 04-23-2008, 03:04 PM
powers84's Avatar
are you sure i think they do.....15x10s rear and 15x7 fronts,tires and rims it came up to $900 or so thats cheap thats with nitto's all around but what shouls the backspaceing be on the front with a 15x7 rim ????.....4"
Old 11-30-2008, 07:22 PM
98Camarod's Avatar
did you end up using the 15x7 fronts?
