nitto drag radials psi
Old 01-09-2009, 06:01 PM
mandreake's Avatar
Default nitto drag radials psi
to use the nittos drag radials on track what psi is used
Old 01-09-2009, 08:47 PM
ALLMOTOR346CI's Avatar
I'd say anywhere from 15-20psi......
Old 01-09-2009, 09:55 PM
Super Speed's Avatar
I ran mine at 18 fwiw
Old 01-09-2009, 10:09 PM
98nosz28's Avatar
I ran mine at 18psi hot.
Old 01-09-2009, 10:58 PM
01trans am's Avatar
Do yall run them that low at all time or just at the track.
Old 01-10-2009, 12:08 AM
SPEEDYTRANSAM1996's Avatar
i run them low at the track only cause i dont want the outter walls to be eattin. i say start at 18psi then drop to 15psi your going to have to play with it. thats what i do. We all have different shocks,suspen. and weight so the tires are going to function different and pay attention to your time slips
Old 01-10-2009, 12:15 AM
Ls1Rook's Avatar
Does it matter the size of the tire ... lets say a 315/30 on a 17 rim? on 15psi looks almost flat.. and feels heavy
Old 01-10-2009, 08:44 AM
ndfrsd6's Avatar
on a nitto 15 is way to low ....there sidewalls dont wrinkle like a m/t ..i say 17-19 on a nitto
Old 01-10-2009, 08:52 AM
bww3588's Avatar
i ran 17 cold in mine, after the run, they were around 20. hooked good.
Old 01-10-2009, 09:00 AM
Randy WS6's Avatar
I run mine at 20psi.
Old 01-10-2009, 12:06 PM
I run mine at 20 on the street whenever I ran them at 25 the middle was all worn and the outside had a LOT of thread left, not sure why though
Old 01-10-2009, 01:28 PM
Ls1Rook's Avatar
Whats the size are the tires you guys use?
