Which Y2K Repo's, 17's or 18's?
Old 02-02-2009, 07:55 PM
96gt4.6's Avatar
Default Which Y2K Repo's, 17's or 18's?
Getting ready to buy a set of wheels for the 'camaro, need some advice. Should I get 17's or 18's? I want 18's, but also want Fuzion ZRI tires. Only size made is a 265/35ZR18. Vs. The 275 I can get for the 17's. Not a HUGE issue really.
My other concern, are you guys having any fitment/rubbing issues with the 18's up front? The fitment guide says they will work on my '00 no problem. It's not lowered or anything.
Thanks in advance!
Old 02-02-2009, 08:17 PM
Donohue96M6Z28's Avatar
18s for sure, 17s are too damn small when it comes to y2k wheels. Also, as long as you have the right size tire up front(275/35/18)/correct offset for the wheels. You should have no issues up front.
Old 02-02-2009, 08:32 PM
96gt4.6's Avatar
Awesome. I was thinking the exact same thing, 18's or nothing. I'll probably be running the 265/35R18 since Fuzion doesn't make a 275 in the 18", or at least that I can find. So rubbing shouldn't be an issue at all.
Thanks!
