Pics of deep dish black C6 ZO6 wheels (big pics)
Here are few pics of my new wheels which are gloss black with a machined lip. Sizes are 18x8.5 front (+45mm offset) and 18x10.5 rear (+56mm offset). Tires are Toyo T1R in sizes 275/35/18 front and 295/35/18 on the rear. Originally, I didn't plan on using the 275's up front, but I remember how the Toyo's run small compared to other brands (they actually measured much smaller than the published specs). Anyway here they are.
Very nice! I can't wait to get mine on in the spring. I got the same setup only mine have rivets or whatever you wanna call them. What kind of springs are you running? any mods need to be done ex. bfh? and did you use spacers in the back?
where did you get them?!?!??! ive been looking everywhere for those but in a staggered set, and even the company that makes them(OE wheels llc) doesnt have them in stock.
can you pm me the info? that would be awesome!!
Biffstupid - No BFH on the rear needed. I do run a small spacer only to push the wheel/tire slightly out for looks. I tried them without the spacers and they were fine. The rear springs are cut and I have QA1 shocks (adjustable height) on the front with stock springs. I may lower the front by an additional .25", but I will wait.
MurderedOut - That is the same place I bought them from.
That looks great! I bought my C6 wheels from OE wheels and I have read a lot of complains about them! I got lucky and my wheels balanced fine but there has been a lot of people get bent rims from them and they wouldn't fix the problem!! I like my C6 rims but I wouldn't buy rims from them again! I still haven't been able to get an invoice from them and I have talked with them 4 times!
blitzed96 - I couldn't get a straight side shot because of all the snow on ground. I just backed it out to my driveway and took the pics.
SOULPOWER - Yes, that is where I bought them from.
Yes the lips are different. The wheel with rivets has a rounded stainless lip where mine are machined (clear coated) with an angular lip. I don't know about the actual difference in depth for the lip.
