View Poll Results: which tires
MT DR's
68.75%
Hoosier DR's
31.25%
Other, specify
0
0%
Grow some nuts and get a 315
0
0%
Voters: 16. You may not vote on this poll
MT DR's vs Hoosier Daddies
Old 02-09-2009, 11:39 AM
streetassasin's Avatar
Default MT DR's vs Hoosier Daddies
Which would be the best, they are going to be on my SS, with prc 2.5 5.3 heads, ms3 cam, circle d 4c converter and 3.23 gears with basically stock suspension. Its my DD but I only live a mile from work and plan on going to the track atleat once a month so they need to be some what streetable. I was thinking the mickeys but not too sure if they will hold with stock suspension in a car that is making around 550rwhp and 600rwtq. They will be a 275/40/17
Old 02-09-2009, 12:09 PM
ndfrsd6's Avatar
im partial to m/t 's but hoosier's hook very hard also
Old 02-09-2009, 12:19 PM
blk/slvr02ss's Avatar
I have M/T ET Street Radial's on my last 3 SS's and they work great all around.The Hoosier's are a wrinkle wall and make your car sway @ high speed's but they hook great also.
Old 02-09-2009, 12:52 PM
Chris05ssTruck's Avatar
MT's work, however i have been hearing good things outta the hoosiers!! My buddie has them and loves them, they just don't last as long as the mickeys. Wouldn't wanna drive either set in the rain.
I will prolly try a hoosier next as i am m6 and that sidewall might help a lil being softer.
Old 02-09-2009, 01:22 PM
kdavis's Avatar
i have the mts and i loved them. i am only making about 400 at the wheels and have lcas and relocation bracket and they would not stick. the track prep was ok, but you should realy go with a bigger sidewall. Is that 550 on the bottle or motor?
Old 02-09-2009, 01:31 PM
550 on a 150 shot
Old 02-09-2009, 02:21 PM
ndfrsd6's Avatar
uhh the hossier dr is like the mickey drag radial ....there radials so there much more stable at speed and dont sway . the bias ply mickeys and the hoosier Q.t pro's require tubes to be more stable at speed
Old 02-09-2009, 02:49 PM
Photochop's Avatar
I've had both, I'd go with the MTs. They will hook very similar, and the MTs will last you longer and be more stable when turning and if you get caught in a rain somewhere.
Old 02-09-2009, 06:15 PM
98mysticZ's Avatar
just bought me some 335/35/17s i should be getting them mounted soon.... hoosiers
